Fuel Filter change instructions for all the newbies (with pics)
Hi, all I just did my fuel filter change and thought I would take some pictures and write down some instructions for all the newbies needing advice for a fuel filter change on a 3rd gen. Thought maybe it could be a sticky
To start off, here are the easy instructions:
Fuel filter change procedure.
1) turn the yellow water seperator valve and let everything drain out. (i like to extend the hose to reach bucket for less mess)
2) get 1 1/8" socket and unscrew the filter lid, this will also help drain fuel out faster
3) take out old filter AND o-ring
4) wipe out the inside if necassary (but you shouldnt need to do it, unless there is a ton of gunk in there, IMO risk for getting lint in the container)
5) stick on new filter AND o-ring
6) lube the o-ring
7) stick it back in the canister
8) turn the seperator valve back to normal
9) twist the fuel filter cab back on snug (or i believe to 24 Ft Lbs)
10) turn the key a couple times (bump start the engine this get the pump goin longer)
11) and start that sucker up, easy as pie
Now for my pictures:
Fresh fuel filter
Hose extension to catch fuel in clear bottle
Turn the yellow drain valve, and unscrew lid
Take out old filter and O-ring
Put on new filter
Lube new O-ring
Drop assembly into canister (after checking for debri on inside of canister)
Close the drain valve
6) lube the o-ring
Fresh fuel filter
Put on new filter
Lube new O-ring
Glad it will help you out. I would like to get stuff like this posted for all the regular maintenance items... oil change, front and rear (i should of taken pictures last saturday), tranny, transfer case ect ect....
It is supposed to be changed every 10,000 miles. Not sure what the effect with bio diesel is. I am pretty sure you are supposed to change it before running bio diesel. If it were me I would still change it every 10,000 miles. $10.00 and 5 minutes keeps piece of mind
Good idea HorseHauler. I'm planning on doing front and rear diffs, transfer case and NV5600 this weekend (just spent $140 in fluids). I'll try to remember to get the camera out there.
Bio acts as a solvent and will loosen up any gunk that's built up in your tank and lines so you'll probably need to change it shortly after starting to run bio. You may have to do 2 or 3 changes at shortened intervals. This is just what I've read, maybe somebody who has experience running bio will chime in.
If you get the transfer case pics that would sure help me out, I don't even know where to start for that. I was gonna let the dealer do that one, but if it is easy, then I will do it myself.
Many thanks to Horse Hauler, I will be going through this in a week or two. Good point about the possibility of getting lint in the canister from wiping it out. You could blast it out with an aerosol product like brake cleaner, and for some strange reason napkins from most fast food restaurants are lint free.
