carrier bearing replacement
Old Jan 10, 2007 | 08:53 PM
patriot dodge's Avatar
I had the carrier bearing replaced last year when I started to hear it howl and now it is doing it all over again has any one had this problem more than once or is it just my luck.
Old Jan 11, 2007 | 02:55 AM
DrDiesel's Avatar
Exclamation
Are you referring to the rear diff. carrier bearings.
If so, you should have had the pinion bearing`s done too.
Half the job the first time = a complete job the second time.
If you have over 50 K on the diff. now, and need to go back in. Do a complete rebuild with ring and pinion gear. My.02
Old Jan 11, 2007 | 06:24 AM
I dont know if it is on the rear diff or what all I know is that they call it a carrier bearing and I am getting that humming like I did last time when it was a carrier bearing and I only have 18000 miles on truck luckily it is still under warranty, I was just wondering if anyone else was having the same problems.
Old Jan 11, 2007 | 07:24 AM
floridagc's Avatar
the carrier bearing is the connection of the two drive shafts the one leaving the trans, and the other headed to the rear end. The cannot place one shaft because of length and angle so hence two drive shafts. Is your truck lifted and oversize tires? this will cause a problem if you do not have the carrier bearing shimmed to compensate angle on pinion.
floridagc
Old Jan 11, 2007 | 03:09 PM
My truck is not lifted or nor does it have over size tires it is all stock. It is a 2005 I was just wondering if they have alot of problems with the carrier bearings.
Old Jan 11, 2007 | 04:56 PM
floridagc's Avatar
patriot, no my shutters but no howling, did you check the drive shafts to see if one is bent or out of round, easy way is jack up the rear and run some chalk lines around the drive shafts and see if one is out of spec with a timing light. Or just take it to the dealer and have them check it. Same thing happened on a gm and it took about four bearings before the figured it out.
floridagc
Old Jan 11, 2007 | 05:06 PM
Rocky5.9's Avatar
Don't leave U-joints out of the mix too. Mine made some awful noises when one was going out. So I installed some new ones with grease fittings.
Old Jan 11, 2007 | 08:59 PM
chighley_00's Avatar
I had my front carrier bearing replace for a humming noise it sounded as if it was in four wheel drive. They replace the carrier bearings and the ring and pinion. After about a thousand miles it was back in the shop for the same noise. This time they replaced the carrier the ring and pinion and all the bearing noise is gone for now.
ajb1974
Mar 18, 2015 05:49 PM
onetwopunch
Oct 11, 2008 09:32 AM
Horsecrazy
0
Apr 12, 2008 10:27 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
