Can't get high idle to work
I have a December 04 Dodge with the 555 engine. I've grounded the #22 pin and have a Smarty Revo program loaded. I can't get the high idle to work. With the pin grounded will my clutch switch still work? Any suggestions?
It has to be enabled AND activated. Smarty only activates the feature. You will need a delaer with a StarScan tool to enable the feature. Most of the manual trucks shipped with the feature disabled and deactivated so its a 2 step process, one of which the dealer has to do.
StarScan is a dealership device..not the same as a code scanner. More than likely a dealer is the only place that is gonna have it. My dealer will only charge 1/2hr shop labor for something like that. So figure $35-$50 depending on their rates.
Am I missing something? I thought with the 6-speeds you had to ground a pin on the ECM to get the feature to work. Are you saying that the dealer can enable it with a StarScan without any physical modifications?
Yes, the dealer can enable and activate it in the ECU. It won't work until pin #22 is grounded with the pig tail or the clutch switch is added.
Hintonc393
Feb 4, 2012 05:02 PM
jmccart
Jun 12, 2007 02:12 PM
pet05
Oct 5, 2006 11:02 AM
