Can a Trans from 07 4wd Work in 04 2wd???
Old Aug 10, 2009 | 06:44 PM
Deezuhl77's Avatar
The question is not only can it drop right it but what if the transmission is from a 4wd 3500.. can it be directly swapped into a 2wd 2500??
I am not looking to convert 2wd to 4wd so please dont misunderstand.. I am simply looking to see if i buy a trans from a donor vehicle that is 4wd can it be swapped into my 2wd.. Thanks for the info.. I searched but couldnt find a direct answer..
Mike
Old Aug 10, 2009 | 06:54 PM
Spooler's Avatar
The backhalf of the trans if different since it bolts to the transfer case on the 4x4. Some of the parts will interchange though.
Old Aug 10, 2009 | 08:28 PM
no_6_oh_no's Avatar
Swap the OD units between the two and use the 04.5 TV cable lever and it will work fine.
Old Aug 10, 2009 | 10:23 PM
Deezuhl77's Avatar
Can you break it down a little more for me.. Sorry , i am not a retard but just dont know all the Technical diesel terms.. Thanks for the help buddy, I appreciate it!!
Mike
Old Aug 10, 2009 | 10:45 PM
RiverRat2's Avatar
Mike
The Out drive halves (back half/Tailshaft) needs to be swapped out between the two trannys and it will work,,,,,,,,,,,,,,,, as long as you use the 04.5's TV Cable lever (whatever that is!!!!!)
Old Aug 11, 2009 | 06:18 AM
no_6_oh_no's Avatar
What he said.
The overdrive is contained in the back half of the trans or tail shaft, and just referred to as the OD unit.
The 05 and newer trucks had a throttle valve motor instead of a cable like yours to control TV pressure. You need to take the linkage and levers off of yours and swap them over to the new trans if you do it.
FYI, if you do this swap its a good idea to have a professional trans shop swap the OD units to make sure the clearances get set correctly in the OD clutch pack. If they aren't correct there will be issues.
93Fury
Mar 31, 2010 01:33 PM
skahla
Nov 20, 2009 08:13 AM
Jordan5687
Feb 18, 2009 02:48 PM
lews930
Dec 8, 2006 10:11 PM
1320
May 6, 2003 06:30 PM
