Torque Converter Drain Back
Old Aug 10, 2009 | 03:02 PM
Mutt68's Avatar
Is it normal to have torque convertoer drain back occur if the truck has sat for 9 months? When I fired up the company truck (2006 Dodge 2500 CTD) I put her in reverse and nothing.....drive..nothing. Put her in neutral and let her run 30 seconds or so and she dropped into gear no problem and ran like a champ from then on out. Is this normal after sitting for 9 months?
Thanks,
Old Aug 10, 2009 | 03:12 PM
RowJ's Avatar
Anything's possible after 9 months!
I would say valve body drain...past the check ball that normally holds the fluid in, but could be other things as well.
Always a good idea to allow some recirculation time before putting in gear. After 9 months, I'd say it's essential!
RJ
Old Aug 10, 2009 | 03:18 PM
blacksmoke06''s Avatar
Yes I think that it is pretty normal. My truck does that when I let it sit for a couple weeks in the driveway. After 9 months like RowJ said having it recirculate is essential.
Old Aug 10, 2009 | 06:04 PM
cbrahs's Avatar
there is also a valve in the tranny cooler line. mine is doing the same thing overnight. last time i checked the valve was on national back order. tired of putting it into gear and sitting there for a minute to get fluid primed up again.
Old Aug 10, 2009 | 08:32 PM
no_6_oh_no's Avatar
Thats the drain back valve, if its doing it overnight its either stuck open with garbage or you got another problem.
Replace the manual valve in the VB with a Sonnax piece and drill that drain back valve out and life will be MUCH better, for your trans too.
Old Aug 10, 2009 | 08:37 PM
cincydiesel's Avatar
I've had the same problem since I went to a Goerends setup.. She sits overnight and I have to let it sit for about 20 seconds before she'll go.. Thought that it had something to do with my shift enhancer.
Old Aug 10, 2009 | 08:56 PM
no_6_oh_no's Avatar
I have the shift enhancer also, set on tow or race depending on the TM. I have let mine sit in airport parking for 4-10 days, start it up put it in gear and go. This is with the Sonnax manual valve originally and with the Transgo kit and stock manual valve and VB mods latest.
I got rid of the drain back many moons ago and have never had an issue with priming.
Old Aug 10, 2009 | 09:00 PM
1985cucv's Avatar
no 6 oh no knows i did this as well much happier. it doesnt take any time to put into gear. ball is removed if you remove it just make sure you got the connections tight i didnt and she leaked a little bit.
I am not a tranny guro by any means and this is getting irratating.. Could I take this to a local tranny shop to have fixed? Not going back to Iowa anytime soon
Old Aug 10, 2009 | 09:12 PM
no_6_oh_no's Avatar
Depends on what the problem is and the quality of the shop. Some I would not let them wipe the dipstick.
I would call Dave Goerend first and tell him whats happening, its sounds like it might be a seal in the TC or something like that. He should know right off where the problem is.
Old Aug 11, 2009 | 08:08 AM
RowJ's Avatar
I would assume Dave removed the check ball on purpose. DTT does the same.... for better fluid flow!
Requires 30 sec to refill after overnight draindown. Is that really a hardship?
Well worth it to me in exchange for cooler fluid temps and a strong aftermarket tranny.
IF it bugs you...get a remote start/turbo timer installed! Good idea to let the engine wake up a bit, anyway.
I use mine everyday, leaving work. Ready to go by the time I walk to my truck.
RJ
Old Aug 11, 2009 | 08:14 AM
j-fox's Avatar
Just let it refill. Do you know it takes 30 seconds for the oil to reach the turbo? Good gosh give it a chance.
If it is so bad that you need to fix it, the bushing for the torque converter is most likely the issue. You may have run out on the trans locator pins. It may be a valve adjustment too on the valve body.
Old Aug 11, 2009 | 08:36 AM
RJ
I think you may have misunderstood me guys. Its irritating that I spent alot of money on a transmission and read a post that states that I may have a problem. If indeed Dave removed the check ball for better flow and this is the side effect, I'm fine with that. Again, if you look at my statement you'll notice that I stated "I AM NOT A TRANNY GURO". I was looking for some possible answers as what the problem (if one existed) could be. NOT a bash on my patience.
Old Aug 11, 2009 | 08:37 AM
jughead's Avatar
the torgue flite trans has had this problem since 1966. i worked on them for 10 years some of the fixes would work on some of the trans but not on all of them. if after market manual valve didnt fix it i just gave up and lived with it. start it in neutral, fasten seat belt and one is good to go.
Old Aug 11, 2009 | 08:56 AM
RowJ's Avatar
I'm fine with that.
Sorry about the misread! Good luck!
RJ
blacksmoke06'
17
Dec 30, 2009 05:21 PM
garretch
Aug 14, 2006 03:15 PM
Bad Ramer Jamer
20
Jan 14, 2006 12:10 PM
TexasCTD
Apr 13, 2005 09:38 PM
got...DIESEL?
Oct 23, 2004 02:19 AM
