Cab odors
Old Nov 13, 2004 | 08:53 PM
sweetwaterguy's Avatar
Cab odors
I have an 04 cummins with 7500 miles. Occasionally I get an oder when I am stopped or immediately after I shut it down that reminds me of a solvent similar to acetone. My dealer has no explanation. Any other similar problems out there?
Old Nov 13, 2004 | 09:42 PM
ckennedy's Avatar
do u have your crank case bypass hose routed towards the back end?? May not be THE smell - but it does cause issues..
Old Nov 14, 2004 | 07:42 AM
lschultz's Avatar
Thats the ole crankcase vent fumes. If your dealer don't know that I would find another one the knows something about these engines. Some brands of oil or worser than others usually goes away after several hundred miles. Just add you a piece of hose to the end of it and extend it back further and no smell.
Old Nov 14, 2004 | 09:30 AM
I am new to posting on forums, and now know what a valuable resource it is. Thank both posters for the info. Much appreciated!!
Old Nov 14, 2004 | 04:17 PM
ppod's Avatar
I get a strong odor when I use my windshield washer with the outside makeup air on. Took me a while to figure it out, but that was it. When I run out in the resevior, I'll try to find something that doesn't smell so bad.
Old Nov 14, 2004 | 06:40 PM
nord's Avatar
I think you'll find that these trucks must have been designed by bloodhounds. If there's a smell to be had, then the RAM moves it into the cab to share around. Smells include roadkill, smoke, and whatever the vehicle in front has already burned.
I haven't noticed diesel smells or crankcase odors from my own truck. In fact, the 600 tailpipe odor doesn't smell all that much like diesel. What I do notice is any gasser in front of me who's really working... Nice sulphur odor just like I was directly behind their tailpipe.
I suspect that the design of the cab somehow directs these odors to the intake and there may not be all that much of a fix. Then again, it hasn't caused me any real worry and I love the truck.
Old Nov 14, 2004 | 07:11 PM
westcoaster's Avatar
I'll second the washer fluid. stick your nose in the washer fluid resivoir and inhale deeply.....
Old Nov 15, 2004 | 09:39 AM
Lightman's Avatar
My truck doesn't make crankcase or any other odors inside the cab, however like Nord, I definitely notice when I'm behind a gasser going up a hill or something, that sour sulfury burnt oil smell is awful. I'm contemplating one of the Cab Fresh Filter kits from Geno's. They are only $59 and filter all the incoming air. Not so impressed with the looks of it, but I may give one a try.
dockrocker
39
Apr 24, 2011 09:43 PM
greasemonki
Dec 21, 2005 06:14 AM
Holsteinman
Nov 3, 2005 08:12 AM
midwestdually
Jan 12, 2004 10:35 AM
PurdellMGP
May 28, 2003 10:49 AM
