Buying a 300,000 mile /06
Old Mar 30, 2013 | 07:13 PM
Durgan's Avatar
Ok well I found a 06/ 2500/ 4x4/ auto/ and would appreciate some insite before I buy.
Old Mar 30, 2013 | 10:15 PM
jbritvar's Avatar
Don't do it. Especially from an autobroker. If you do, take it in for a full service - an additional grand or 2. I got screwed when I bought an 180k 07. Motor, injectors, everything.
Old Mar 30, 2013 | 10:37 PM
Durgan's Avatar
I know that's what I've been thinking!! But everything on the truck is clean and it's $8,900.00 so the next 2006 is 20K so maybe spending 5 K to fix something that will be going out soon anyway at a lesser mileage and more expensive truck. What do you think ? I really appreciate your input.
Old Mar 30, 2013 | 10:47 PM
jbritvar's Avatar
If you buy this truck what I reccomend is the following: Injector Test, fluids change (all fluids; oil to differential), and filters filters change. If anything is seriously wrong then it will be noticable unless you have leaking rings and are gettin blowby like I was. You also have to consider that is a lot of driving for an 06, so you have to consider chasis condition as well as electrical system condition. I had a 94 12 valve that was pushin 320 and the electrical issues on that thing were non stop. After my experience I will never by a used truck again after what Ive been through (3x what I paid for it to have it running). If I were you I would also consider just buying one from a dealer. That way you know they put sometime into making sure things check out.
Old Mar 30, 2013 | 10:53 PM
Durgan's Avatar
You know what you are absolutely right!! What I want I need are two different things . I want a nice diesel, but I need dependable cost effective solution. Well played Sir, thank you
Old Mar 30, 2013 | 11:33 PM
rjm022's Avatar
at that mileage you will probably be replacing something soon.. something simple and expected.. water pump,etc or unfortunately.. something major, like a turbo! at least have the injectors tested. check the color of the tranny fluid! with that many miles and not being the original owner, be willing and ready to put some money into her in the next year or two for any wear and tear items and/or neglected items that will fail
Old Mar 31, 2013 | 12:12 AM
Durgan's Avatar
I think my ambition will best served by sucking it up and saving the money first. I don't have credit, all I have is what the president likes to call change ( in my pocket ) . Thanks guys !!
Old Mar 31, 2013 | 01:25 PM
jbritvar's Avatar
No worries. Take it from me though. I bought an 07 5.9L with 180K in Salt lake. Bad choice to begin with from a autobroker. Didnt take it to get serviced caz i dont drive it much at school. But in december, pistons 1,3 and 5 blew out the block. Since then I have spent ovr 25k for a new motor and fuel system, as well as the inbetweeners. good luck to ya
Old Mar 31, 2013 | 02:50 PM
Durgan's Avatar
Thank you very much for advice.
Old Mar 31, 2013 | 11:19 PM
Kach's Avatar
FWIW - 300k isn't much worse than 150K in my book. Either way, you have a lot of unknowns. May need injectors, trans, clutch, fuel pumps etc. Will likely need lots of U-joints, brakes maintenance etc. I bought my '03 for about $20k a year ago and have another $3K or so in general repairs and preventative maintenance. I think it's still a bargain compared to a new truck at $60k and plenty reliable still at 137K miles for my uses.
I looked into trading it in for a manual truck, but decided I wasn't willing to "start over" on all of the wrenching and parts I've thrown at my truck. I try to look at whatever little upgrades or maintenance I can do when I have a bit of money in my pocket. I know I'll eventually probably get hit with a set of injectors or tranny, but once those get done it shouldn't be a problem again for a long long time.
Old Mar 31, 2013 | 11:26 PM
Durgan's Avatar
Yea the issue I have goes back to it is a auto broker sale, and it's more than I can afford to gamble on. I have had all new diesel trucks, but since I had to close my company and get a J-O-B, it's probably left until I can pony up for a lower mile truck with some love given to it !! Haha
Thank you tho
kenni
62
Mar 11, 2012 08:46 AM
APD
Aug 16, 2010 07:54 PM
guzzimaster
20
May 9, 2007 08:37 PM
DRM
Aug 11, 2005 09:34 AM
BigBlackDodge
Jan 9, 2003 05:45 PM
