300,000 mile maintenance check
Rolled over 300k the other day on my truck. Only owned it since 273k, so I have little info on what was done before I got it.
What should I check, or replace at this point - from a pure maintenance standpoint?
Location: Used to be missoula, montana: Now in Sonoma County California
Rear axle seals and bearings
U-joint
Ball joints
Tierod ends & track bar
Hydraulic hoses and vacume lines
Fuel lines
Flexable brake lines & brake cylinders
Front wheel bearings steering column bearings
Radiator
Tenssioner for your accessory belt. those tend to have issues late int eh life span around xxxxx hours. LOL
automatic
its a 12v
check your fuel return check valve
consider a new lift pump or at least giving yours a good hard look.
My old truck i replaced the check valve between 100k-150 and did the lift pumps between 130-150k each time
truck had 400k when sold
U-joint
Ball joints
Fuel lines
Radiator
automatic
its a 12v
Track bar was replaced a few months ago, P/S pump ad steering gear box was replaced a few weeks ago - as well as checking all steering parts for looseness and wear.
I think I am gonna replace the check valve here shortly, along with going through and replacing soft fuel lines.
Thanks for the tips, just gonna make a list and start doing one or so a week.
[QUOTE]Originally posted by ddestruel
Do you have any more info on the steering column bearing.
That is the problem I have my shaft moves all around, cumming out from the fire wall.
Thanks Mike
Thanks Mike
Originally posted by DRM
check valve
check valve
http://dodgeram.org/tech/dsl/trouble...p.htm#Overflow
[QUOTE]Originally posted by mrwaters
I had a buddy of mine who is a dodge tech rebuild the column for me. the upper bearings were showing thier age and the lowe bearing was loose like you are describing.
Thanks Mike
Thanks Mike
kenni
62
03-11-2012 08:46 AM
schorb
20
06-15-2006 10:19 PM
