Broken Radiator Drain Plug
Old Oct 15, 2009 | 09:46 PM
hknladdr's Avatar
Help. Opened the radiator drain today for a coolant change. When I went to close the drain it would not tighten, just spun. When I tried to pull it out to check the O rings only the stem/**** portion came out. Now the other portion is stuck in the radiator? Ordered a new drain valve from dodge but need some idea's on what to do w/ the piece still in the radiator.
Old Oct 15, 2009 | 10:05 PM
bansh-eman's Avatar
See if you can't push the peice you have back in there. When you go to tighten the plug, you have to push up on it to get the threads to bite, other wise it just spins.
Old Oct 15, 2009 | 10:45 PM
hknladdr's Avatar
I have tried pushing in hard and turning but the threads will not bite.
Old Oct 16, 2009 | 06:41 AM
mini14's Avatar
epoxy it shut for good, if u cant easily fix it. The next time u need to drain rad, just pull the lower hose...although its never happened to me, if it did, i wouldn't let it bother me. ive drained and filled mine a couple of times and those plugs r flimsey.
Old Oct 16, 2009 | 08:58 PM
Old Smoky's Avatar
I have heard that you can find a good replacement unit in the Help! section of carquest.
Mike
Old Oct 16, 2009 | 09:49 PM
Dr.Dizzle's Avatar
Mike
I have heard that the "Help" section of AutoZone also carries them.
mossyoak11
Oct 29, 2010 02:34 PM
klx650a2
Jan 10, 2008 12:08 AM
gsdog1
Aug 1, 2007 05:04 AM
timcasbolt
Jul 7, 2007 12:40 PM
kevinn
Jul 17, 2005 10:40 AM
