Brake light and ABS light on, codes 26 and 34
Old Oct 7, 2020 | 10:20 AM
welndmn's Avatar
2005 truck.
Just recently while driving the Brake and ABS light both came on.
I pulled OBD codes first and got the p2509 code only, this was because my battery went bad about a month ago, I replaced the battery and deleted the code, it has not came back.
I bought a better scanner to where I can pull ABS codes and got 26 (Missing sensor LF) and 34 (My scanner did not know what this is).
The ABS sensor seemed to OHM out fine, but I put a new one on the Driver front anyway, deleted codes, and they came back right away.
The speedo works just fine.
Any ideas here?
Old Nov 19, 2021 | 05:26 PM
jda51's Avatar
5 Year Member
Had this problem on a 2000 2500 4x4. turned out to be the module with the two hydraulic solenoids by the ABS module.
MTRK2002
Feb 14, 2011 09:26 AM
TOM R
Jul 23, 2010 03:19 PM
paulrecore
Mar 28, 2010 02:33 PM
crash4wd
Jul 28, 2009 08:35 AM
Sootman
23
Dec 29, 2004 09:12 AM
