Abs light on
Old Feb 13, 2011 | 04:55 PM
MTRK2002's Avatar
Exclamation Abs light on
Can anyone help me out here,after getting stuck in the snow last week my ABS light came on not right when I got stuck but later that day.It is only my ABS light the brake light is not on as most of the other post on here say they are getting both lights I only have the 1 light and no codes I tried to reset it by disconnecting batteries waiting 20 min. and turning key on and hitting brake to no help though light still on never went out at all . any help would be appreciated.
Old Feb 14, 2011 | 09:26 AM
cbrahs's Avatar
as for codes, a general scanner will not read ABS codes.
i would check the tone ring to make sure it is not packed full of junk to cause a false reading with the mag pickup. pull each abs sensor on the front axle and clean. rear axle only has the 1 sensor. if you got stuck bad enough to damage the wires, check them out.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
