brake issues.
Old Apr 10, 2012 | 09:40 PM
hot shot's Avatar
brake issues.
abs and brake light are staying on.used to come on and go off but stays on now.brake pedal went to the floor the other day and almost ran my boat over then i was pulling into the gas station today and hit the brakes and pedal wouldnt move for a second.then started working but almost ran into the building.any ideas?
Old Apr 10, 2012 | 09:59 PM
BigIron70's Avatar
Cummins Guru
Check brake fluid level first, if full most likely master cylinder is bypassing internally. If empty you could have brake fluid leak or brake pads are worn out and require replacing. There will be a code or codes stored in ABS module since the code is active now.
Old Apr 11, 2012 | 08:36 AM
hot shot's Avatar
thanks
fluid and pads are good.will look at master cylinder.
schoust
Dec 10, 2006 06:57 AM
Earthmover627
Nov 21, 2006 05:50 PM
Twogun
Oct 29, 2006 08:44 AM
rednose
Jan 17, 2006 05:07 AM
partytyme
Oct 7, 2005 08:58 PM
