brake disk hub turn or replace?
Old May 15, 2013 | 04:33 PM
RHC's Avatar
RHC
Bought truck new. just got 100,000 miles on her. Factory brakes just now need changing. disk rotors are warped.Disk rotors have alot of wear.what rotors should i get if going new.....factory or after market?
thanks
Old May 15, 2013 | 10:53 PM
.boB's Avatar
First off, are you sure they are warped? You cannot tell by pedal feel any more. You need to put a dial indicater on them.
http://www.stoptech.com/technical-su...nd-other-myths
But, with 100K on them, they're probably worn enough to warrant replacement. The best bang for the buck is Duralast from Autozone. $62, 2 yr warranty. They work as well as anything else on the market, and better than many of the trick parts.
Old May 16, 2013 | 04:37 AM
RHC's Avatar
RHC
The brakes feel like they have high spots on rotor when stopping
Old May 16, 2013 | 11:44 AM
pronstar's Avatar
Pulsations are often an uneven transfer layer of pad material...
Old May 16, 2013 | 08:37 PM
Spooler's Avatar
Need to mic them out to see if after you turn them they will still pass spec. Most of the time that number is stamped into the rotor if you can see it.
Old May 16, 2013 | 09:17 PM
roughstock's Avatar
Get QUALITY replacement rotors.
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
Rafter B
Jan 11, 2009 08:40 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
