Blowing white smoke on startup
Old May 2, 2023 | 11:06 PM
noahg22's Avatar
I bought my smarty tuner for my 04.5 cummins about 4 months ago. It was in January so it was cold and i’ve been used to a little bit of white smoke because of the cold, but now that it’s may and starting to warm up i’ve noticed some smoke still happening. It oddly enough doesn’t happen in the morning when it’s a little cooler and the heater grid runs but any time I leave it sitting for over and hour It will start easy but then blow a decent cloud of white smoke and idle a little rough for 20 seconds. Is it something I should be concerned about or is some smoke with a tuned truck normal?
Old May 3, 2023 | 07:13 AM
Fordzilla's Avatar
When I had the Smarty on my previous truck, a 2003, I could change the settings...Can you go back to stock, or a different setting to see if the smoke changes?......Ben
Old May 3, 2023 | 08:56 PM
noahg22's Avatar
Yep, returned to stock and still happening. I just changed the fuel filter about 2k miles ago to a baldwin 3 micron. I’ve read some more and it could be some bad diesel that I got recently. Any ideas on good additives to clean injectors or should I just flush it and hope it goes away in a tank or two?
Old May 14, 2023 | 06:30 AM
haily grace's Avatar
I think you can find multiple youtube videos about cleaning injectors
turbopilot51
Feb 20, 2008 08:02 PM
Fredbearstalksm
25
Dec 22, 2007 04:36 PM
tobyw
Feb 15, 2005 11:48 AM
shaft
Jan 30, 2004 11:54 PM
big b
Jan 11, 2004 12:15 PM
