white smoke during warm ups
Old Jan 30, 2004 | 11:43 AM
shaft's Avatar
Angry white smoke during warm ups
It's been about 10 below zero in the past few mornings when I warm up the truck. I've been getting a lot of white smoke when I start it and eventually goes away after the truck warms up. Is this normal? Thank you for the input.
Old Jan 30, 2004 | 11:46 AM
bulabula's Avatar
Normal.
I think the manual says that if you cycle the grid heaters a couple of times the white smoking will be minimized.
Old Jan 30, 2004 | 01:42 PM
RamDan03's Avatar
Yep, normal....you will even see a little coming out of the tailpipe on some cold mornings if you look in the side mirror.
Old Jan 30, 2004 | 05:16 PM
cp's Avatar
cp
White smoke, or condensation? At -10, I would think what you're seeing is condensation.
Condensation is just water vapor. White smoke is unburned fuel. Usually, white smoke is accompanied with somewhat rough running because (I think) white smoke can only be emitted on a cylinder that didn't fire or at least barely fired. White smoke also has an eye burning, smelly characteristic.
Old Jan 30, 2004 | 10:43 PM
mymaur's Avatar
Normal.
Probably smells pretty foul as well.
Old Jan 30, 2004 | 11:54 PM
Vaughn MacKenzie's Avatar
It's better for it to warm it up by driving it instead of letting it idle. Let it run a couple minutes to get oil circulating then drive gently for the first couple of miles.
Vaughn
46mech
Mar 17, 2011 10:21 PM
hertz
Apr 12, 2006 05:49 PM
ratsun
Dec 27, 2005 11:53 AM
RED99CTD
14
Dec 8, 2005 11:00 PM
