Blowby brake boost test?
Old Dec 27, 2018 | 06:35 PM
Txc's Avatar
Txc
10 Year Member
Hey guys, I had a rebuild done on basically EVERYTHING this time last year...build has about 40k on it...i have noticed for about a month that my truck leaves a few oil spots of oil on the floor every morning. I am fairly modded and run between 40-50lbs of boost and am trying to determine if its just a typical 5.9 leak or if I have a problem.
I do not have oil in my coolant and no fuel in my oil. I hve tested blowby throughout the rpm range and hot or cold get nothing but a slowly rotating oil cap. No pressure or smoke. The truck runs Rotella T6 full syn and JUST did a oil change this week.
Now i tried a different kind of blowby test where i brake boosted to 10psi and check for motion and the cap raises up but did not fall out when I got above 7psi....should I expect this to be normal as the valvtrain needs pressure to move oil around?
I have recently cleaned the ccv and breather tibe but not the drainback tube yet...so i might do that still. Truck runs great great mileage and is not burning oil or leaking enough to put drops on my tailgate.
Old Dec 29, 2018 | 11:38 AM
Txc's Avatar
Txc
10 Year Member
Bump
Old Dec 29, 2018 | 12:10 PM
StealthDiesel's Avatar
Where is it leaking from?
Old Dec 29, 2018 | 12:42 PM
Txc's Avatar
Txc
10 Year Member
The breather tube. A single drop or so after it sits.
Old Dec 29, 2018 | 03:55 PM
That's totally normal and better than most including my truck since new.
Old Dec 29, 2018 | 04:28 PM
Txc's Avatar
Txc
10 Year Member
At 150k yes normal...but not at 40k on a new motor hence my worry...
Old Dec 30, 2018 | 11:08 AM
Txc's Avatar
Txc
10 Year Member
Bump
92smokin blacky
Sep 27, 2011 04:02 PM
redpoint5
Jun 29, 2007 09:45 AM
Bobcat698
Jul 11, 2006 11:52 AM
KATOOM
Apr 29, 2004 12:25 AM
