blowby test
Old Jun 28, 2007 | 11:28 PM
redpoint5's Avatar
blowby test
I was quoted $105 for 1hr to test the blowby on my truck at Cummins NW. I'm wondering if I can do this myself relatively easy. I just want to make sure my engine is good for many more miles before I spend a ton of money on a new tranny. Engine has about 180,000 miles on it.
Should I test the blowby or compression or both? There are cheap magnehelic gauges on ebay.
Old Jun 28, 2007 | 11:36 PM
LOGAN's Avatar
Muted User
pull your oil fill cap off, im guessing they are like our 12 valves??? rubberband a plastic shopping bag with no holes in it on the fill tube, should inflate the bag if there is blowby, this is the way ive always done it with gassers. do 24 valves have down draft tubes for blow by???? never messed with a 24 valve so im using the SWAG method on this one.
Old Jun 29, 2007 | 09:45 AM
infidel's Avatar
Making your own blowby tool is easy.
The blowby orifice tool Cummins uses is simply a tee with one .221" (15/64-in) outlet. Connect one end of the tee to the end of the blowby tube. Put a manometer on last tee outlet. That is your blowby tool. They sell them at the Cummins, but I have made my own plenty of times, less than $10. A simple manometer can be made by looping into a 'U' 6 feet of clear tubing with water in it half way. Measure how high the water level rises with a tape measure, multiply it by 2, convert it to LPMs.
Rough conversion is 1"= 27 lpm, add 3 lpm for each one inch (1/2'' of rise in the tube) of water
The reason for multiplying by 2 is that inches of water equals the water rise in the open end of the tube plus the inches the water is pushed down on the engine side of the water tube. For simplicity my numbers below are the measurement of rise only.
Cummins new 5.9 engine numbers are:
63 liters per minute(2.5" water rise) @ 2200rpm,
76 L/Min (3.5" rise) @ 2500rpm
85 L/Min (4.5" rise) @ 2800rpm.
Worn engine that needs rebuilding are roughly double i.e.
126 L/Min(10.5"rise) @ 2200rpm
152 L/Min(14.5"rise) @ 2500rpm
170 L/Min(17"rise) @ 2800 rpm
Beside indicating a compression problem the valves could also be out of adjustment.
Another way (mine), same idea, is to block the blowby tube with a 1/2'' pipe nipple with a cap that has a 15/64 hole drilled in it. Use 3/8'' id looped clear tubing with water in it slipped over the oil dipstick tube. Other tubing end remains open. Use a sharp tipped felt marker to mark the water level with the engine off, have a helper start an already warmed up engine and run the rpms up to 2.2, 2.5 & 2.8k rpms. Mark each water level with the pen, measure the distance from engine off mark then multiply each by 2.
This is all very simple to do, just hard to explain with words.
SilverDiesel
Oct 10, 2003 12:55 AM
Evildiesel
Oct 29, 2002 05:22 PM
