Best way to find TDC??
Old Dec 19, 2007 | 11:50 AM
05Supersomker's Avatar
What is the best way to find TDC on an '03. I know the damper is marked but where is the reference point to that mark??
Old Dec 19, 2007 | 11:59 AM
dodgezilla04's Avatar
12 oclock. straight up.
Old Dec 19, 2007 | 03:28 PM
Nuttymopar's Avatar
If still not 100% sure. Remove front (#1) valve cover, move mark to noon position (Straight up) and both your intake and exhaust valves should be slightly loose. If both are not, rotate motor 360* and check again. Both should be slighlty loose.
Old Dec 19, 2007 | 08:46 PM
What is the sequence for the valves?? Tell me if this is right #1 TDC Intake 1,2,4 Exhaust 1,3,5 then rotate 360 and set the rest?
Old Dec 19, 2007 | 09:34 PM
jrs_dodge_diesel's Avatar
Here you go, this should be very helpful to you.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
robert97dodge
13
Aug 3, 2012 06:55 AM
92smokin blacky
Mar 10, 2011 09:30 AM
Checkmate
21
Apr 6, 2008 09:08 AM
1980240D
Nov 25, 2007 10:57 AM
logan21sv
Oct 17, 2006 11:09 PM
