BD overdrive lockout for '05 questions......
OK guys I need help AGAIN!!
I've installed the unit per directions with one exception, I ran the power for a location which is 12 volt switched, but not from the fuse box location shown (I think it says #29). If it calls for 12v switched location, wouldn't you think it shouldn't matter where I get it. I powered it from a source off of the steering column that I found when I hooked up my radar detector. Do you think there is an issue with the current draw? Also, with the blue and violet colors being used, I got help with the colors because I've got poor eyesight.
But maybe they could be reversed, but I don't think so......
Anyone else had issues getting these things to work.....I have power going to the unit (14.4 volts) but no LED showing the unit is engaged....HELP!
jaredb900rr
01-13-2009 10:53 AM
Offroad9
33
12-06-2006 09:59 PM
