Battery Cables
Old May 31, 2014 | 03:09 PM
AkitaSumo's Avatar
Battery Cables
I need a new passenger side battery ground cable and the dealer wants $106 for it. The other dealer in town was at $112. I ran across a company called Custom Battery Cables, has anyone here dealt with them before?
http://custombatterycables.com/appli...0_3500_5p9.htm
Old May 31, 2014 | 09:22 PM
Spooler's Avatar
Noop. Never dealt with them before. It's just a ground, it should be OK.
Old Jun 3, 2014 | 09:25 AM
masterphreak's Avatar
I had the local Interstate Battery shop make me a custom set when I replaced mine, cost me about $140 or so if I remember correctly. They have worked great since. Of course the connecter that bolts to the fuse box isn't the same as the factory one, but i saved almost $200 on the overall cost of replacing the complete set. If your are just replacing the ground cable I would say go for it.
Old Jun 3, 2014 | 06:38 PM
rockcrawler304's Avatar
Or check you local welding supply store for some 2 gauge grounding cable. Most sell in bulk (cut to length) and you can put some new ends on it. They come with a very durable casing too!!
Old Jun 3, 2014 | 10:04 PM
AkitaSumo's Avatar
Thanks guys, I went ahead and ordered the cable. Will post pictures before installation.
Sent from my Nexus 7 using Tapatalk
Old Jun 18, 2014 | 03:39 PM
AkitaSumo's Avatar
Battery terminal clamp and ground lug to fender
Ground lug to engine block
Sealant and heat shrink tubing
Sent from my SCH-I535 using Tapatalk
Old Jun 18, 2014 | 10:33 PM
HMX-1's Avatar
BTW, this is how I made my set of jumper cables. The last set I made lasted 15 years before they grew legs and walked off a job site my folks had.
-Kris
Old Jun 19, 2014 | 02:37 PM
AkitaSumo's Avatar
This was the quickest solution for me at this time. I am very impressed with their product. A whole lot better than OEM.
Ordered on Tuesday, received on Friday...
taildragger
38
Dec 19, 2006 09:49 AM
Hoss15
Oct 27, 2005 11:06 AM
leprechaun
Sep 14, 2005 08:20 PM
banzaitoyota
Sep 29, 2003 04:36 PM
ggolub
Jul 5, 2003 06:16 AM
