Batteries being drained !!!
Old Dec 3, 2012 | 06:33 PM
Z-MAN's Avatar
Hello everybody, I recently returned from a year long deployment aboard Big "E", to find, among other things, that my batteries were dead. Replaced them with two new Optimas but after a few days they were sucked. Unless I remove the white fuse from the box, they will keep losing their juice. I know I have two good batteries but something keeps draining them. Performed a visual inspection and couldn't find any bad wiring. Any ideas will be greatly appreciated. Thanks.
Old Dec 3, 2012 | 10:49 PM
Recon2531's Avatar
Parasitic drains can be hard to find. A good multi-meter is all you need to diagnose it most of the time. Disconnect neg cable from battery, connect meter in series one lead to neg post on battery, other to neg cable. Put meter on D/C amps. Anything over about .2 amps is too much. All this is done with key off, all accessories off, doors closed. Once you actually see the draw on your meter start pulling fuses one at a time until you see the drain or amp draw go away on your meter.
Old Dec 3, 2012 | 11:29 PM
47Dodge's Avatar
Bad Diodes in the alternator can cause this..............
47
Old Dec 5, 2012 | 01:50 AM
Z-MAN's Avatar
Thank you both for your replies, I will check both things. Wish you all Happy Holidays.
Old Dec 5, 2012 | 08:29 AM
Shorts's Avatar
+1Recons suggestion. That'll get you on the way.
Go Navy! Z-man, welcome back. And on the Big E for her last trip. That's something. Take care.
arroyojim
Oct 9, 2014 09:14 AM
ado2b1
Jun 24, 2009 01:42 AM
fitzydog
Apr 23, 2005 07:42 PM
fitzydog
Apr 21, 2005 09:04 PM
mr T
Jan 31, 2005 06:16 PM
