batteries drained - question
Old Oct 4, 2014 | 08:14 PM
arroyojim's Avatar
just recharged my batteries after finding them dead.
Now with neg cables detached from batteries, positive cables attached, key is off, everything off:
Voltmeter reads 12V between battery terminals
No voltage between positive terminals and neg cables,
but reads 12V between neg terminal and neg cable.
does that sound right?
Old Oct 5, 2014 | 12:27 PM
APD's Avatar
APD
Remove positive cable from battery.
Test for continuity between positive cable and ground/neg cables.
Old Oct 5, 2014 | 02:28 PM
patdaly's Avatar
You need to test for key off amperage draw, not voltage.
With batteries fully charged, key off, remove the positive terminal and see what amperage is being drawn ( VOM set for Milliamps ) between the positive post and the terminal.
Shouldn't be more than 30 Ma if I remember right.
Old Oct 6, 2014 | 10:25 AM
joem's Avatar
aftermarket radios and alarms can be power hogs.
Old Oct 9, 2014 | 09:14 AM
Stamey's Avatar
Separate the batteries and test them independently. I had a draw I was searching for over a 6 month period, and it turned out to be a weak battery which I didn't find until I separated the batteries for testing.
Chris
Z-MAN
Dec 5, 2012 08:29 AM
ado2b1
Jun 24, 2009 01:42 AM
fitzydog
Apr 23, 2005 07:42 PM
fitzydog
Apr 21, 2005 09:04 PM
mr T
Jan 31, 2005 06:16 PM
