ball joints ALREADY????
Old Nov 19, 2007 | 12:11 PM
BAD GRAVY's Avatar
just had an alignment done on my 06 2500. tech showed me on the lift that the ball joints are worn out.. come on it has 23k on it.is this normal? has anyone else been told this???
Old Nov 19, 2007 | 12:34 PM
ssandlin's Avatar
I would'nt think it's normal, I've got 44K on my 06 and no problems yet. With only 23K on yours, I'd be at the dealer ASAP!
Old Nov 19, 2007 | 01:51 PM
OOPS's Avatar
Do you have a lift or leveling kit on it?
Old Nov 19, 2007 | 02:44 PM
Bark's Avatar
This probably doesnt apply to you but I had a "tech" in CO (I was getting an oil change far from home) show me that my ball joints were bad at 45k miles. Drove it to CA and had a dealer look at it. They said they were good. That was 20k miles ago and still no problems.
Old Nov 19, 2007 | 05:02 PM
tool's Avatar
I had a flat repaired recently and had them rotate my tires while it was on the lift. (at a local reputable tire and repair shop that I do a lot of business with all the time).
Same thing they said my ball joints have considerbale play in them at 28K, on a COMPLETELY stock truck.
They advised me to keep driving it to the very end of the warranty and take it in.
Said they would put it back on the hoist and show me where the play was so they wouldn't B.S me at the dealership.
That is ridiculous!
I put 100K on the Moog Replacements in my second Gen and they are still good.
Old Nov 19, 2007 | 05:14 PM
Patriot2500's Avatar
My stock ball joints went out at 66k and I have a leveling kit and 35's, also plowed 3 storms with the truck last year. Buddy of mine has an '05 with 20k and had to replace his ball joints already and his truck is all stock. I went with the MOOG replacements and haven't looked back yet. It is nice to have more than 2 grease fittings under there.
Old Nov 19, 2007 | 05:15 PM
BAD GRAVY's Avatar
yes i do.we just put a leveling kit on and new shocks,took it right away too be aligned.thats when i got the news.?? the front end feels good to me.
Old Nov 19, 2007 | 06:52 PM
mikmaze's Avatar
my stocks went out at 29 k , conveniently the same time my first injector failed........
Old Nov 19, 2007 | 11:15 PM
Smalz's Avatar
where to get Moog
Where did you get moog replacements?
Old Nov 19, 2007 | 11:46 PM
mikelr's Avatar
I think I read somewhere that the stock ball joints on the late model trucks have a lot of slop in them from new. Maybe these shops are just used to tighter joints and are mistaking ball joints that are within spec as far as lash as bad??
Old Nov 20, 2007 | 06:29 AM
I got mine from the shop who did the work, but I believe you can order them online. Try Napa maybe?
Old Nov 20, 2007 | 10:27 AM
BigHornCTD's Avatar
My '06 has 26K on it and the driver's side is already developing play. So based on this and all the other threads I have read, yes it seems to be normal. Vehicles that drain your wallet seem to be the norm these days.
Old Nov 20, 2007 | 02:31 PM
Bark's Avatar
Thats what I wonder about. The shop in CO that wanted to sell me new ball joints didnt really seem like a rip off joint and 20k miles later the truck still isnt pulling or having abnormal tire wear.
Old Nov 20, 2007 | 11:46 PM
Rod_Montana's Avatar
It's the stock joints. I had my 05 truck realligned when the bigger diameter tires were installed. (285/17). They said, looks loose. Dodge dealer said the same and did the warranty repair. Took it back and guess what? Same with new joints. Loose, but not bad. They really did change the joints. I watched the process. But as the dealer did not have an allignment rack, we went back to my fave place for that.
New M55 Toyo's in the spring (when the new 285's come out)... then Moog, with Camber correction. My right front needs that as it's on the edge of spec.
Old Nov 21, 2007 | 10:45 AM
LanceK's Avatar
How can you tell if they're loose?
Can it be felt through the steering wheel?
My steering feels a little sloppy lately at 34K.
