ball joints ALREADY????
Old Nov 26, 2007 | 08:57 PM
07Dually's Avatar
I have a 07 Dually 4x4 with 6" lift and 22.5 alcoa and my shop today was going to do alignment and the passenger side ball joint no good I have had this setup sine May rougly 20000 miles.
Old Nov 27, 2007 | 10:52 AM
Rod_Montana's Avatar
The allignment shop jacks up the front axle until the wheel hangs in air. They then put a bar under the tire and lift it up and down, watching for movement in the lower ball joint. In my truck the movement (joint moving in and out of socket) was close to but less than around .100". It was the same, both before and after the replacement. 12k miles on the old joints, 8 miles on the new joints.
You can't feel any problem at the wheel. There may be some additional tire wear (cupping), but nothing radical with this degree of "loose". It was the same on mine. Passenger side looser than driver. That's also the side that needs some camber tweaking with an offset ball joint.
moparonly
Aug 17, 2013 03:32 AM
firebill1720
20
Mar 5, 2010 09:23 AM
NickBeek
Dec 14, 2007 10:37 PM
caper
Apr 12, 2005 07:20 AM
