Bad Luck
Old Jul 3, 2008 | 03:46 PM
04dodgeHO's Avatar
Bad Luck
So I just passed 100,000 miles got bad gas replaced the entire fuel system and then for some reason the belt tensioner broke. So a month later and about $5000 i got it back. Now my fuel mileage went to crap. Lost about 4-5 mpg. Whats up with that. I figured the new cp3 had anough pressure with the new injectors that I was using more fuel. I don't drive crazy but it does seem like it runs 300 times better.
Any thoughts.
Old Jul 3, 2008 | 03:59 PM
snoyes's Avatar
What are you seeing for fuel mileage now vs before? If it is running 300 times better, I probably be happy with that. Did anything else change with your truck, ie, bigger tires? Also, have you calibrated your speedo to a GPS? And are you hand calculating or using the overhead for your fuel mileage?
Old Jul 3, 2008 | 07:27 PM
04dodgeHO's Avatar
I am using the overhead and handcalculating it. Before I was seeing arounnd 21 on the overhead and around 19 hand calc. Now I am seeing 19 and about 15hand calc. Nothing else has changed.
babyray55
Jul 2, 2011 02:43 PM
Homestead
ABDTR #5
19
Jan 31, 2009 11:52 AM
ratlratl
Nov 9, 2008 10:37 PM
Dodgezilla
47
Feb 22, 2008 10:02 AM
cameroneod
16
Oct 5, 2007 12:36 PM
