Bad Boost Gauge Or is Something Wrong
I have a bone stock truck and lately it has been registering 1.5 - 2 psi at idle in gear or out of gear. WOT I get about 25 26 psi which is normal for my truck. It is an autommeter phatom series gauge about 2.5 years old. I first noticed this last winter and then in the summer it was normal 0 at idle in gear or out of gear. I do notice when out of gear and I push on the go pedal it will drop a little then go up, it does it very quickly. Is this a sign that the gauge is bad or something is wrong with the truck? The truck runs great. I appreciate all replys thank you.
madhat I had a problem a year or so ago with my trans temp jumping so O soidered all my connections. I thought boost gauge was vacum or preasure and the wires were only for the lights? Thanks for the reply I will recheck the wires again.
Good point... I'd pull the end from the intake manifold (or, where ever you have it mounted at,) and put compressed air on it, a low PSI, and watch your guage. I assume that you checked your line, I'd put a little soapy water on the connections and see if you have a leak. Always start with the cheepest thing first... maybe the line took a poop?
wesboyd585
Jun 12, 2009 11:37 PM
deezulsmoke
26
Jan 28, 2005 11:13 PM
