Back in Action
Old Apr 19, 2017 | 06:20 PM
GIT-R-DONE's Avatar
Back in Action
I have been out of the Cummins market for a while now, and just bought an 07 5.9 QC short bed all stock with low miles. It is an auto 4x4. With all this electronic BS nowadays....who can answer some basic questions for me ?
What is the trans number for the autos in the 5.9 ? Anything to watch out for ? This is my very first auto trans and am skeptical about it.
Where can I find out the rear gearing ratio at? Its not on the window sticker other than being an 'anti-spin'
What turbo would be on this truck and does it have a silencer ring on it like the old HX 35's did ?
What kind of fuel pump are on these trucks now ? In tank of external like the old lift pumps were?
TPS on it ?
Tips or things to look out for ?
Thanks and its good to be back !
Old Apr 19, 2017 | 06:44 PM
steelblitzkrieg's Avatar
DTR Detective
48RE
Most likely 3.73, I think it's in the glove box on a label. (If I recall 72mph at 2k RPM is 3.73)
Yes, silencer ring
In-tank
FILTRATION FILTRATION FILTRATION!
Other than a cracked body on an injector (Which was obvious) every issue I've had, set a code that was easy to diagnose.
I have 140K I've done 4 injectors, 2 FCA's, 1 Tranny, 2 brake light switches, 1 mutli-function switch, the rest was all front suspension or normal wear parts Brakes/Batteries, etc. I feel like I'm forgetting something mechanical but it must not have been too bad if I forgot it.
Last edited by steelblitzkrieg; Apr 19, 2017 at 06:46 PM. Reason: Added commentary
Old Apr 19, 2017 | 07:30 PM
GIT-R-DONE's Avatar
ok, what is an FCA and how does one go about checking for codes or do I need a code reader ? I think my 02 I had to cycle the key a few times to get a code to flash....
Old Apr 20, 2017 | 10:17 AM
DTR Detective
Fuel Control Actuator
10 minute change, symptoms are rough driving engine cut-out.
Codes
Cycle key, can never remember if it's 3 or 4 times.
CaptainChrysler
Aug 1, 2009 08:11 AM
ViperSBT
Oct 13, 2008 07:13 PM
Ground Shaker
MODTR #30
36
Feb 4, 2008 06:41 PM
JoshPeters
Apr 3, 2005 08:13 AM
