axel nut help
Old Apr 30, 2009 | 10:49 PM
dodge em's Avatar
axel nut help
did a search found like 10 post non of which helped too much,
is it 1-11/16? or metric? Where will i be able to find one? I got a kit from the parts store but it stops at 36mm which is too small. Thanks
Old Apr 30, 2009 | 11:08 PM
b wojo's Avatar
If its the front retaining nut you are talking about I believe its 44mm
Old May 1, 2009 | 12:46 AM
pullin hard's Avatar
gee, i can't rememeber which it is now, but i use a socket thats not metric.36mm is too small.
Old May 1, 2009 | 06:16 AM
elirandolph's Avatar
I used a 1-11/16 and it worked perfectly.
Old May 1, 2009 | 06:26 AM
hot shot's Avatar
used a 1-11/16 and it did the trick.check at the parts store.some places keep them behind the counter so dont just go in a nd look ask someone.or if you have a place that services 18 wheelers or any kind of big trucks check with them.
Old May 1, 2009 | 11:34 AM
Chip's Avatar
I also used a 1-11/16 socket and did the job flawlesly.
Chip
Old May 1, 2009 | 08:05 PM
mini14's Avatar
yes its 1 11/16, which is easy to find, it is also 42.93 mm which might be hard to find. its like 3/4in. is 19mm same sizes its a tomato toemato thing.
Old May 1, 2009 | 11:42 PM
dodge em's Avatar
to better a search and after awhile doing it the word to search is "nut".
My problem after 9 stores is was finding a 6pt socket, no luck. so i got a 12pt and 3/4-1/2 adapter and it ziped right off with my impact. Im good, so thank you for they replyes
mt250
Aug 5, 2009 11:34 PM
artieb
Mar 4, 2008 11:16 AM
Dr. Evil
Mar 18, 2007 11:28 AM
JImbo1
Apr 9, 2003 07:46 AM
