Awful bumpy ride!
Old Nov 10, 2007 | 10:13 PM
Big-D's Avatar
Awful bumpy ride!
I recently bought an 07 Mega cab 4x4 2500 5.9. It rides terrible down the interstate. Feels like it is shaking my teeth loose. No kidding. Every little bump rattles this thing. Even the steering wheel shimmies. Is this common with the dodge rams? Is there anything that can be done to smooth it out?
-BD
Old Nov 10, 2007 | 10:20 PM
ptgarcia's Avatar
Money will smooth it out.
Old Nov 10, 2007 | 11:14 PM
Mopeman's Avatar
Ummm, no offense but it is a HD truck. Check the tire pressure, if the rear is up around 55-60psi, then the truck will ride really hard. Set the rears to 40 to 45 psi and it will help out a lot. Keep the front around 60 and the MPG 's will be ok. The ride will smooth out a bit with some miles on it too. Have fun with the new rig....
Old Nov 10, 2007 | 11:29 PM
nitis's Avatar
yeah my guess is you came from a half ton
Old Nov 11, 2007 | 10:26 AM
Big-D's Avatar
Nope. I traded an 01' F-350 7.3 that rode waaay better. It got better mpg too.
Old Nov 11, 2007 | 10:53 AM
Vinceg99's Avatar
I wouldnt expect too much on the MPG's right now, how many miles do you have? and is it the 5.9 or the 6.7? The more miles on they seem to get a bit better fuel mileage but I havent heard the best for MPG's on the 6.7's. Also is it a SRW or a DRW? Might need to be loosened up a bit but also the stock shocks arent too great.
OOPS's Avatar
Check your tire air pressure and use what the manual for loaded and unloaded. Made a world of difference on my 04.
Old Nov 11, 2007 | 11:32 AM
megafast's Avatar
I believe that my Bilstien's helped my ride. lower tire pressures help greatly. Other than that, its a heavy duty solid axle truck.
Old Nov 11, 2007 | 11:50 AM
Vinceg99's Avatar
And here I dont think mine drives that bad and all my tires are set at 80psi! I usually have heavy trailer on but even without it it isnt horrible. I do need shocks though that I can tell.
Old Nov 11, 2007 | 11:52 AM
Sevir's Avatar
upgrade your shocks, makes a world of differance
Old Nov 11, 2007 | 10:58 PM
Big-D's Avatar
It is the 5.9 with SRW. Probably does need to be loosened up a bit but my F-350 never rode this rough. Was thinking going from 1 ton to 3/4 ton would make for a better ride.
Old Nov 11, 2007 | 10:59 PM
Big-D's Avatar
What shock do you recommend? Do levelers help?
Old Nov 11, 2007 | 11:23 PM
JRAPTOR04's Avatar
I put a lorenz level kit on with bilsten shocks and it rides waaaaaaaay beter know, my wife loves it compared to stock
Old Nov 12, 2007 | 07:50 AM
TRC51's Avatar
Did you do the rears as well? If so, which option?
Old Nov 12, 2007 | 01:15 PM
Sevir's Avatar
alot of people run the bilsteins, and alot run the rancho's. I just went with one from sears because i am 2wd. It made a world of differance. The levelers dont do anything but take the rake out of the truck.
