Awful bumpy ride!
Old Nov 12, 2007 | 03:19 PM
Rednecktastic's Avatar
Yeah I put a lorenz kit on my truck too and it helped... The larger tires helped too. 17 inch wheels and 315/70 tires.
It still doesn't ride like a new half ton but it doesn't beat me to death anymore.
Maybe you can try some 285/75/17 tires from Toyo or 305s (I think these fit without lift) from BFG or someone if you don't want to do suspension. Otherwise lower your tire psi some within the safety margin.
And for shocks... Bilstein shocks, I got mine from Lorenz too.
Old Nov 12, 2007 | 09:12 PM
Big-D's Avatar
Originally Posted by Sevir
alot of people run the bilsteins, and alot run the rancho's. I just went with one from sears because i am 2wd. It made a world of differance. The levelers dont do anything but take the rake out of the truck.
I understand they take the rake out of the truck but doesn't that also shift some of the weight towards the back?
Old Nov 12, 2007 | 09:19 PM
DWK's Avatar
DWK
I think you just end up getting used to it. I cam out of a Ford SD also and mine rides like a covered wagon as well. So far I've done tires, 3x, shocks, dual steering stabilizer, air bags, level kit blah, blah, blah. Still dosent ride as nice but I'm getting used to it. Tire pressures seemed to help the most. I like everything else about the truck though, especially the motor....
Old Nov 13, 2007 | 09:03 AM
HOV's Avatar
HOV
My truck rides like a dream compared to the kidney-destroyer Duramax I had. That thing had bouncing rubber ***** for rear shocks.
Old Nov 13, 2007 | 04:04 PM
Big-D's Avatar
Maybe i'll throw 500 lbs in the back and see what that does. Do shocks alone make that much difference?
Old Nov 14, 2007 | 09:48 AM
enafzige's Avatar
The Lorenz dual purpose leafs are truly amazing...the ride is night and day different!
Old Nov 14, 2007 | 03:46 PM
bsj04's Avatar
here is an idea... read on its pretty good
https://www.dieseltruckresource.com/...rete+bed+liner
Old Nov 14, 2007 | 08:16 PM
jamesbfishin's Avatar
I must be nuts then.... Cause I thought the ride in my truck was too soft. Tire at 65 lbs front and 50 rear. The front end felt more like an suv than a real truck. Of course I had also just gotten rid of a 97 F350 crew and that thing rode like a park bench... (like a truck) and I loved every kidney popping bounce.
Old Nov 14, 2007 | 10:15 PM
Big-D's Avatar
I think i'll start with the sand bags...
Old Nov 14, 2007 | 10:17 PM
Big-D's Avatar
Maybe your leveling kit smoothed it out... Mine is still stock.
Old Nov 15, 2007 | 10:31 AM
Rushford's Avatar
i put about 6 buckets full of sand (300-400lbs), easy to take out, and does make a difference on the free way. on smooth roads its great.. on the roads we are lucky enogh to have out here in CA its ****.
Old Nov 15, 2007 | 12:29 PM
Peterbilt's Avatar
I use a mouth piece to protect my teeth. Mine is so stiff when I drive over a dime I can tell if it's heads or tails
Pete
(xploretx)
Old Nov 15, 2007 | 03:32 PM
LFD2037's Avatar
Pete
(xploretx)
HAAAAAAHAAAHAAAHA!!!!!!
Old Nov 15, 2007 | 05:03 PM
Big-D's Avatar
Pete
(xploretx)
Thats funny. I was thinking about a mouth guard while I was driving down the interstate but then I hit a french fry and lost my train of thought... Thanks for reminding me. Lol
Old Nov 15, 2007 | 06:37 PM
The leveling kit actually has coils that are 6% stiffer than stock ones, it made the front end tighter and more along the line of what I'm used too. The truck was too soft for me when it was stock, felt kinda mushy, and the body rolled too much in turns (and I drive like an old lady, or so I'm told). The leveling kit helped tighten things up and reduce body roll.
