Auto Tranny is slipping...help
Old Nov 7, 2010 | 06:46 PM
tywebb3's Avatar
I noticed recently that my tranny is slipping when in drive. When I put it in drive and hit the gas the truck acts like the parking brake is on. It move a little but it takes a lot of gas. One time it almost felt like it "dropped in" and then went fine. Lately I have been starting out in "1" and shifting manually to get around this.
I checked the fluid and it is to the top of the range but I noticed it has a brownish tone to it. It is an '01 with about 80,000 miles on it.
Is this a typical scenario with these trucks? If so, what is the fix? I know a local guy that is real good at working on these trucks and I was going to give it to him but figured I would check here first to see what you all think.
Old Nov 7, 2010 | 06:53 PM
06RAM2500's Avatar
When was the last time you had it serviced?? Only thing I can say is drop the pan and see how much material is in it.
Old Nov 7, 2010 | 07:31 PM
Spooler's Avatar
Sounds like the Governor Pressure solenoid and transducer is your problem. If you shift through the gears manually just fine, that is what it is. Put a filter in it while your at it. You have to drop the pan to change the parts out.
Old Nov 7, 2010 | 07:36 PM
tywebb3's Avatar
Thanks for the response. I just noticed I put this in the wrong place....should have been in 2nd gen.
Old Nov 8, 2010 | 05:58 AM
05HDRAM's Avatar
My 2nd gen gasser was acting up. Changed the fluid and it took care of the shifting issues.
rjweiss
Jun 4, 2011 07:48 PM
tywebb3
13
Nov 20, 2010 02:49 PM
Black Dog
Dec 3, 2009 08:18 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
PistolWhipt
16
May 10, 2004 06:05 AM
