Auto Tranny Damage?
Old Mar 3, 2008 | 08:49 PM
tony's Avatar
Auto Tranny Damage?
While sitting in my truck at the local mall waiting for my wife to return, an older man backed into my truck with enough force to push me about 12-18 forward. My truck was in park only. I heard some loud "clicking" from the tranmission.
My question is how to determine if damage has occured to the transmission. It seems to shift as before and it does go into park and holds. How likely is the possibility of damage? Is there anything I can checked with the pan off?
Thanks!
Old Mar 3, 2008 | 09:01 PM
Towmaster101's Avatar
Get some trans qoute's from some aftermarket companies and claim it on your insurance. lol. J/K. Maybe.
Old Mar 3, 2008 | 09:28 PM
Dieselnick's Avatar
That was the park pawl clicking against the flywheel; it may be damaged, but most likely it's OK. It won't affect the operation of the trans.
Nick
Old Mar 4, 2008 | 02:55 PM
dozer12216's Avatar
Check extension housing for cracks, and or oil leaks. Does park still hold on slight grade correctlly and feel normal? Does it start in neutral correct and gear positions still O'K.
Old Mar 4, 2008 | 05:48 PM
tony's Avatar
I don't see any cracks or leaks, and it seems to work as before.
Can the parking pawl slip without breaking the "teeth"? I already had an appointment this week to change the transmission fluid. Can anything be seen from the pan side?
Old Mar 4, 2008 | 11:48 PM
Dieselnick's Avatar
Yes the pawl can slip w/o breaking. No you can't see it with the pan off; you'd have to remove the trans. If it's still working OK I wouldn't worry about it.
Nick
Old Mar 5, 2008 | 09:16 AM
no_6_oh_no's Avatar
Yes, they can jump without hurting things. On the other hand, that much force can also break teeth of the pawl ring, mess up the parking pawl, and crack the pawl mount. The only wya to know for sure is drop the OD section off and check it out.
zethtays
Nov 3, 2010 06:24 PM
lews930
Mar 7, 2007 06:33 PM
bigwheels94
14
Jun 22, 2006 12:10 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
