auto locking hub stuck
Old Jun 29, 2009 | 12:49 PM
weaver740's Avatar
i have an 05 dodge 2500, put it in low range to back a trailer and now the drivers side wheel jerks when you make a turn right or left like it is still in 4 wheel drive. jacked the truck up turned the right wheel it turns freely but the left wheel turns the front drive shaft.when you crank the wheel to the left or right you can't turn the tire. hope someone has some sugestions.
Old Jun 29, 2009 | 02:22 PM
whitebuffalo's Avatar
05 has no lockouts. there is no 2wd low. the 4x4 lever engages and disengages the tcase, thats the only disconnect point there is.
once you shift back into 2wd, sometimes you have to drive a little bit to unbind everything before it'll get back into 2wd. mine does it best if you'll put your wheels straight and just go easily a few feet.
Old Jun 29, 2009 | 02:30 PM
bradler's Avatar
if you cant turn it with the steering cranked could be a shot axle u-joint.
Old Jun 29, 2009 | 07:01 PM
no_6_oh_no's Avatar
Bad ujoint.
Old Jun 29, 2009 | 07:04 PM
Cujo_07's Avatar
^^ that would be my guess too.
Old Jun 30, 2009 | 10:59 AM
billie's Avatar
Not bad, broken would be my guess. Only reason I can think of to turn a tire and not turn the driveshaft since I doubt the pumpkin is shot. Should be easy to see.
Old Jun 30, 2009 | 11:16 AM
isb07's Avatar
100 % u joint same thing happened to me
Old Jul 2, 2009 | 05:43 AM
weaver740's Avatar
Thumbs up
thank,s to everybody that replied you were right on,it was the u-joint.a little difficult to get apart but i got it.
05 QC edge juice w/attitude 4" magnaflow exhaust volant intake
Rafter B
Jan 11, 2009 08:40 PM
Baja
Jan 29, 2008 08:17 PM
Timberman
Jul 20, 2007 09:11 PM
xp8103
Dec 25, 2005 09:45 AM
Mark Hodowanec
Aug 4, 2004 10:01 PM
