Anybody Know what the stock Map should read
Pluged in my little reader and went for a drive!
Map reading maxed at 37.7
Is this normal?
Cant help but notice this is 23 psi over atmospheric.
Truck works okay just curious!
Is this normal?
The ECM reads the absolute pressure, so you'll need to subtract atmospheric from it to get the boost reading. 23psi sounds about right if you were getting after it. Now if you see that at idle, then you may have an issue.
I'll take an educated guess and say the wastegate is set to open around that pressure. That would be about 23psi of boost, which sounds close to the wastegate value. But someone with more 3rd gen experience may know for sure.
wilderness
Jul 31, 2014 09:58 AM
bradler
49
Sep 14, 2012 03:12 PM
txarrowhunter
Jul 12, 2009 05:49 PM
Dusty Ratcliff
21
Feb 15, 2007 09:52 PM
endo911rs
Nov 8, 2005 08:08 PM
