Cummins dlr doesn't know what a MAP sensor is???
Old Jan 31, 2005 | 06:05 PM
endo911rs's Avatar
I am having an intermittent loss of power problem. If it happens on the freeway, I can barely maintain 40mph. If it happens around town, I can barely get moving. Then the problem goes away and all is good. It does not run rough, no smoke, only 70,000 miles and the fuel pressures are all normal. I read some other posts that talked about faulty MAP sensors with the same symptoms. I decided to take it to a local Cummins shop but they have no idea what a "MAP" sensor is... Can someone please help... part number? different name?
Thanks, Chris
'01 2500
Old Jan 31, 2005 | 06:28 PM
Sidewinder's Avatar
I'm pretty sure MAP means Manifold Absolute Pressure. It measures the actual pressure in the intake manifold - go figure.
Old Feb 1, 2005 | 08:01 AM
CDRAM's Avatar
Most diesel mechanics, and people in the diesel world in general refer to the M.A.P. sensor as a boost sensor. Map sensor is usually a gasser term. I once asked for a map sensor at Cummins NW, the parts man asked me if that was the boost sensor.
Old Feb 1, 2005 | 08:41 AM
endo911rs's Avatar
Thanks CDRAM, that answers my question! This whole thing has become a big nightmare. I took the truck to Cummins NW with specific instructions, to three different people... run a quick computer check to make sure that there is not anything else wrong with the engine...i.e. fuel pump. But most importantly, I told them to only replace the MAP sensor (boost sensor). THat is it, don't waste your time on diagnostic checks, I would assume all responsibility if "my" diagnosis is not correct. I would expect an hour labor plus parts. I would do this myself but I already had an appointment and felt bad cancelling it.
So I go to pick it up last night which I had previously arranged to do... The part was not replaced, the battery was completely dead and there was a bill for $400! All of which was diagnostic time?!?! I thought I told them explicitly NOT to do that. They did not even find anything wrong with the truck after spending all that time.
I am not sure what is the correct way to handle this problem. Needless to say, I am less than satisfied.
Old Feb 1, 2005 | 02:31 PM
JCHMOTOR's Avatar
I HAD A BAD MAP SENSOR THAT NEVER TRIPPED A CODE INTHE COMPUTER. HAD THE SAME PROBLEM YOU HAD, NO POWER VERY LITTLE BOOST. HAPPENED A WEEK AFTER A NEW PUMP INSTALL. THEY INSTALLED ANOTHER INJECTOR PUMP FOR NO CHARGE AND THE PROBLEM STILL EXISTED. ONLY OPTION LEFT WAS THE MAP SENSOR. NOT A PROBLEM SINCE. THIS I WAS TOLD IS A SIMPLE INSTALL ON THE DRIVERS SIDE OF BLOCK. I THINK ITS NEAR THE LIFT PUMP.
GOOD LUCK
Old Feb 1, 2005 | 03:20 PM
endo911rs's Avatar
Just changed the MAP (boost sensor) and everything seems fine so far, although the problem was intermittant. The part was about $85, much better than $3000 for a new pump! Cummins NW also corrected the bill and misunderstanding.
Old Oct 20, 2005 | 08:03 PM
j-fox's Avatar
Map / boost sensor for a 01 is part number 05017791aa.
My 02 needs a different one .
Old Nov 8, 2005 | 08:08 PM
endo911rs's Avatar
Well... it ended up being the Injector pump. The dealer fixed it under a special warranty. I now have a fuel pressure guage and dual lifter pumps to help prevent this from happening again.
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
thatguy
Oct 23, 2002 05:36 PM
