Any quick fix coolant hose leak?
Old Aug 18, 2007 | 11:36 AM
RyeThomas's Avatar
Winner winner chicken dinner!
While changing out injectors and some other maintenence I happend to put a pin hole in my Heater core supply coolant hose. I cant get one till thursday so my truck is down. Anyone have any ideas of a quick fix to get me to work and back till next week? Its amazing how such a small hole can leak so much once the system heats up and is pressurized. Thanks Rye.
Old Aug 18, 2007 | 12:14 PM
CTDinMT's Avatar
Several wraps of duct tape should hold it or put an innertube patch on it.
Old Aug 18, 2007 | 12:18 PM
FMB's Avatar
FMB
Option 1: Take the bad hose off, take the good hose off the heater core and loop it back to the where you took the bad hose off the engine.
Option 2: Go to the parts store and get a short piece of pipe and two clamps, cut the hose at the pin hole and insert the pipe/clamp arrangement. If you go with this option, I suppose you could just get a replacement length of generic heater hose, huh?
Option 3: CTDinMT's patch with an additional clamp over the pinhole, not real tight, but it will tighten with pressure. Just an extra 'hold'.
94ram
May 19, 2010 01:45 AM
george7941
Nov 28, 2009 09:28 PM
jlipskoc
Jan 29, 2007 02:28 PM
george7941
Aug 10, 2005 07:06 PM
bulabula
May 21, 2004 02:00 PM
