another fuel filter question!
Old Dec 26, 2006 | 09:36 PM
moonshinedoc's Avatar
I have done a search and haven't found what I'm looking for. I saw in a previous post that the 7 micron filter was for 2006 and above. As shown on my sig. I have a 2004 and was about to change my filter with a 7 micron and thought if that post is true then I may need to reconsider and go with a 10 micron. What should I do? I don't want to kill the lift pump!
Old Dec 26, 2006 | 09:41 PM
HorseHauler's Avatar
The 7-micron is for the new ULSD fuel. You will want to get the 7-micron
Old Dec 27, 2006 | 11:18 AM
Thanks! I appreciate the help. What does USLD have in it we have to protect from? I know what it doesn't have more of, just wondering!
Old Dec 27, 2006 | 11:22 AM
madhat's Avatar
Administrator/Jarhead
It's not what the ULSD has in it, it's what it does to the fuel system. The ULSD breaks down all the deposits and trash that are in the tank/lines, and clog up the filter. If the filter catches it. (ergo, the 7 micron)
Old Dec 27, 2006 | 11:40 AM
ROOSTER108BM's Avatar
DC changed to a 7 micron filter because of injector issues.Bosch wanted Cummins to go with a 5 micron instead of the 10 but DC got them to settle for a 7.It has nothing to do with ulsd.
Rooster
Old Dec 27, 2006 | 11:58 AM
jkitterman's Avatar
Originally Posted by ROOSTER108BM
DC changed to a 7 micron filter because of injector issues.Bosch and Cummins wanted to go with a 5 micron instead of the 10 but DC got them to settle for a 7.It has nothing to do with ulsd.
Rooster
If Cummins wanted to go with a 5 micron, why didn't the filters switch for all the CRD diesels Cummins manufacturers? From what I know, the filters haven't changed for the medium duty applications, etc.
Old Dec 27, 2006 | 05:57 PM
Sorry jkitterman, i worded that wrong,(see edit above).Bosch wanted more filtration because of injector failures.Using better filtration has nothing to do with usld,its no different than low sulpher diesel other than sulpher content(doesnt clean tank,fuel lines etc,if this were the case 10 microns would be sufficient in new trucks because there would be nothing in the lines to clean)That being said,there are current issues with fuel contaminates causing injector failures.GM more than DODGE thank God The only filtration problem i could see by ulsd is service stations running tanks low to meet government requirements for sulpher content.
Rooster
Old Dec 27, 2006 | 08:39 PM
Thanks again guys, that explains alot that I didn't know!
Old Dec 28, 2006 | 08:23 AM
Peterbilt's Avatar
ULSD has a detergent effect.
Pete
Old Dec 28, 2006 | 09:32 AM
nelrod's Avatar
I run and in-line fliter from tank to Walbro, then 7 micron, then 2 micron.
nate_88
Jul 20, 2009 08:25 PM
kronikpain
Oct 18, 2006 04:57 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
fortylove
Apr 22, 2006 08:42 AM
roc155
Jan 17, 2006 07:55 AM
