Another 2 stroke oil question
Old Jun 11, 2007 | 04:07 AM
06dodge's Avatar
has anyone tried this oil:
http://www.silkoleneshop.com/product.../15250310.html
it says that it can be used with all fuels? i use silkolene products on my dirtbikes and wondering if this is work it or not?
Old Jun 11, 2007 | 07:56 AM
MikeyB's Avatar
From the specs this is a octane booster and cleaner designed for gasoline engines. No mention of diesels, I would pass and use something that's formulated for diesel fuels.
MikeyB
Old Jun 11, 2007 | 01:01 PM
DBLR's Avatar
Like Mikey B said it looks more like a gas product so I would not use it in my truck.
Old Jun 11, 2007 | 03:39 PM
MEGA COP's Avatar
I'm confused...why would you put two stroke oil on your DIESEL?
Old Jun 11, 2007 | 08:33 PM
06dodge's Avatar
MikeyB
thats what i thought too but is did say good for all fuels in it so it was just a thought since i have some sitting at the house.
thanks for the input
Old Jun 11, 2007 | 11:24 PM
crobtex's Avatar
I use high grade outboard motor oil.....it helps lubricate the injector pump. General opinion is that ULSD does not have enough lubricant.
Old Jun 12, 2007 | 06:05 AM
coolslice's Avatar
I started putting some old cheap 2 stroke oil in my fuel lately. I was unaware that there are some 2 stroke oils that are NOT formulated for diesel??? I thought basically all 2 stroke oil was the same for the most part. I seriously doubt that there can be that much difference.
I also asked my Cummins tech if he thought it was good to run this oil, he said it was probably not a good idea as it could gum up the injectors over a period of time. I just thought I would add that since I have not been able to find Cummin's official stance anywhere. Also, I have decided that I will keep running a small amount of 2 stroke oil. My truck seems to like it. I don't measure the amount, I have just been putting in a few ounces (maybe 3 or 4) at fillup. My exhaust has more of a "diesel" smell now.
Old Jun 12, 2007 | 07:05 AM
MikeyB's Avatar
Two stroke oil with no other additives is fine, I run 32oz of TCW3 (ashless) every other tank.
MikeyB
Old Jun 12, 2007 | 07:51 AM
Ram of Steel's Avatar
Marvel Mystery oil here.
Old Jun 12, 2007 | 08:11 AM
iweb's Avatar
Isn't sea foam made for gas engines and alot of guys use it in dsl trucks?
Old Jun 12, 2007 | 08:39 AM
Mopar1973man's Avatar
Not a good product to use...
http://www.setonresourcecenter.com/m...3/wcd04377.htm
You like dumping Naptha (Zippo lighter fluid / Coleman camp fuel), and paint thinner (mineral spirits) in your tank... No good on fuel system...
Seafoam is NOT recommend it diesels being it mostly alcohols/solvents.
http://www.seafoamsales.com/pdf/MSDS_SFTT_US.pdf <- MSDS sheet from Seafoam itself...
Well here we go... I've been mixing my fuel at a ratio of 128:1. That is 1 oz of oil for every 1 gallon of fuel. My MPG's are rising, my HP/TQ number a good and high, and my engine runs much quietier.
I started using 2 cycle oil at about 87K miles I went from 16-17 MPG's to 18-19 MPG and heading toward 20 MPG's!!!!
http://www.frontiernet.net/~mopar197...el%20graph.jpg
As for the dyno...
http://www.frontiernet.net/~mopar197...dynojet640.jpg
So if 2 cycle oil is so bad why are all my numbers good??? If you want more information on this PM me and I get you set up...
Old Jun 12, 2007 | 01:49 PM
MEGA COP's Avatar
I'll ask this question again, why would you add oil to your diesel fuel?
Old Jun 12, 2007 | 01:51 PM
Rollin' Smoke's Avatar
TOO HELP LUBRICATE YOUR PUMP. then ULSD has less lubrication in it that the old stuff did. your basically just supplimenting the fuel to help lubrication of fuel system
Old Jun 12, 2007 | 01:57 PM
MEGA COP's Avatar
Thank you for answering my question.
Didn't Cummins makes these engines compatible with ULSD? So if I have problems then the warranty should take care of any issues that might arrise from not enough lube to the fuel system rite?
Old Jun 12, 2007 | 02:06 PM
well i think we all know how alot of dealers deal with warranty service
