Amsoil oil w/ leaks?
Old Oct 14, 2007 | 06:45 PM
LFD2037's Avatar
I'm finally @ the mileage to change to Amsoil synthetic motor oil, but I have a ? first. For any of you running Amsoil, does your engine leak oil since you changed over? I was reading somewhere that alot of people were having this problem after converting, so I was wondering if is a problem I should expect to see? TIA
Old Oct 14, 2007 | 08:09 PM
paparcl's Avatar
I bought my truck about 2 years ago and the previous owner ran Amsoil since almost new and I have continued to run Amsoil thru out and have had no leaks, currently at 85,000 miles plus. I have read on this forum that the higher mileage rigs tend to have leaks when changing over. Hope this helps.
Old Oct 14, 2007 | 08:22 PM
PCM's Avatar
PCM
At 15k miles, I changed to Amsoil, a Donaldson EA oil filter and a FS-2500 by-pass oil filter. I have had no leaks what so ever. PCM
Old Oct 15, 2007 | 10:20 AM
toddschwantes's Avatar
I also changed to amsoil 15w-40 at about 40,000 miles (from premium blue synthetic) and I've never had a leak. Truck is 2003 305/555.
Old Oct 15, 2007 | 01:16 PM
LFD2037's Avatar
That makes 0-leaks/ 3-no leaks. I feel better, thanks!
Old Oct 15, 2007 | 01:44 PM
BarryG's Avatar
Been running it in my truck since about 15k now it is at 210k no leaks.
Old Oct 15, 2007 | 02:33 PM
Spooler's Avatar
Changed mine over at 30,000 miles and no leaks.
Old Oct 15, 2007 | 04:49 PM
MOJO1's Avatar
Mine has had it sents new! just put the bypass on with the billet cap looks good to. Truck has 10k on it AMSOIL,The only way!
Old Oct 15, 2007 | 10:26 PM
JohnDeereDodge's Avatar
Amsoil in the engine, transmission, rearend, with an amsoil oil and air filter, No leaks in any and the transmission oil makes for much smoother shifts in my truck! Will be going to amsoil antifreeze and brake fluid soon.
Old Oct 15, 2007 | 11:16 PM
Dieseljunkie's Avatar
There is a common misconception with synthetic oils, that if you switch over to synthetic on a high mileage engine, it will cause seals to crack and leak. This is not true, if you use a pre-cleaning product like Amsoil's engine flush before doing the switch over to amsoil, but this is only for high mileage engines. If you don't have high miles, feel free to switch with no engine flush, and it will be just fine. I've been running Amsoil in my truck for about 30k with no problems.
Scott
Old Oct 15, 2007 | 11:20 PM
rustyshakelford's Avatar
ive been running it for 3k miles and i like it...except it still stinks, i hate that!!!
brett
Old Oct 15, 2007 | 11:23 PM
I love that "stink"
Scott
Old Oct 15, 2007 | 11:25 PM
Originally Posted by Dieseljunkie
I love that "stink"
Scott
i dont. im paranoid i have a leak somewhere...
no b.s. though...it really quieted the motor. i was a little skeptical
brett
Old Oct 15, 2007 | 11:27 PM
Yup. it does quiet the motor down quite a bit
You'd know it if you had a leak.
Scott
Old Oct 17, 2007 | 03:15 PM
PCM's Avatar
PCM
brett
Yes, it stinks! HOWEVER, it will go away by aobut 500 or so miles. Mine is that way at each oil change.
