alternator squeeeel !!!!
Old Dec 26, 2009 | 06:46 PM
1985cucv's Avatar
ok so i was driving the truck in the snow today and the alternator started to squeel if i lube it up it will stop for about a minute and then start again! is there anyway to fix this or do i need a new alternator? is there a replacement bearing of some sort. by the way the truck only has 72000 miles on it thanks
Old Dec 27, 2009 | 08:36 AM
papaduck's Avatar
The squeel could be from the belt slipping on the pully. Make sure the belt tension is tight. Could be the idle tensioner is failing.
1985cucv's Avatar
no one has had this problem? cmon someone must have
Old Dec 27, 2009 | 08:37 AM
1985cucv's Avatar
no tension is tight i looked up on here and i believe the pulley is bad there is a dealer tsb on it but thanks for the help
Old Dec 27, 2009 | 08:40 PM
nedz19's Avatar
I thought i had a similar problem. Put new bearing in idler pulley, used half a can of belt dressing and ended up just needin to put a new belt on and that took care of it
Old Dec 28, 2009 | 07:23 AM
1985cucv's Avatar
it actually fixed itself which was sweet! no more noisemight have been from the cold?
5.9Excursion
Mar 13, 2008 07:08 AM
Ron
Jan 24, 2005 09:29 AM
Evildiesel
Jan 2, 2003 11:00 AM
MADDOG1
Dec 30, 2002 12:02 AM
poolboy
Dec 20, 2002 10:25 PM
