Alphabet soup on the oil
Old Aug 8, 2004 | 12:57 PM
davelinde's Avatar
Can anyone tell me about the alphabet soup I find on the oil?
I did a little looking in my manual and googling and found that I should use 15W40 API Cl-4/SH with less than 1.85 mass % sulfated ash....
ok, the 15W40 part I understand.
I learned that the Cxxx API specs are for "Commercial" and applicable to diesel. The "Sx" specs are for gas.
So I go to pick up some oil and find Rotella T promising low soot and Cummins CES20078, 20077, 20076, 20071 and
API Cl-4/SJ, SL.
Can I ignore the SJ, SL part and not be concerned it's not SH?
What's the CES part? (not mentioned in my owners manual)
No notes about sulfated ash...
I bought it, I hope it's ok to use it.
Old Aug 8, 2004 | 04:34 PM
BigBlue's Avatar
Rotella T is fine. I've been running it for almost 40K miles and knock on wood, I haven't had a single problem.
Old Aug 8, 2004 | 06:01 PM
As long as it's the right weight and it says CI-4 on the bottle, it's OK.
Old Aug 9, 2004 | 10:38 AM
nickleinonen's Avatar
if you are talking about the CI or SG ratings, the C is for compression ignition and the S is for spark ignition
ian515
Oct 16, 2007 07:02 PM
chuxtruk
May 8, 2006 10:25 AM
TxDiesel007
15
Jan 18, 2006 01:19 PM
Lary Ellis (Top)
Sep 24, 2003 07:48 AM
