air dog ?
Old Mar 16, 2008 | 04:11 PM
solostyle1's Avatar
air dog ?
i am in the process of installing a airdog 150. my in the tank pump works on and off. if i leave the wires unplugged so it dont pump fuel, how am i gonna have a fuel guage? can i just route the stock pump lines to each other and let it pump in a circle basically?
Old Mar 17, 2008 | 07:56 AM
HOBrian's Avatar
You are only going to pull the wire for the pump. You can leave all the other wires alone.
Old Mar 17, 2008 | 07:36 PM
Fuel Preporator's Avatar
It looks like you have a 1998.5 Dodge. If that is true, then the in tank pump is a replacement pume. It, like the original that was mounted on the side of the engine, is controlled by the ECM. The Lead from the original plugged into the ECM connection. The in-tank replacement pump that you now have will have a lead from the tank up to the same Deutsch connector that the original pump was connected. Look on the drivers side of the engine toward the back and below the head or in the area on the side of the block for the lead. If you cannot find it, call me at 573-230-8838.
Thanks,
Charlie
duster75
Sep 9, 2009 11:02 PM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
BIGHEAD
Jul 24, 2006 07:49 PM
NWDave
Mar 13, 2003 05:58 PM
