Adjust those bands!
Old Sep 8, 2007 | 11:11 PM
vzdude's Avatar
DTR's 'Go to Guy'
Adjust those bands!
Wow! Serviced my trans today and adjusted the bands as well. All I can say is WOW , what a difference! I found the bands to be wuite a ways out of adjustment. ( I counted the turns to get to the torque setting) I had been having some 1-2 hesitation/stutter . Never really felt like it slipped, but just didn't feel right. Fixed it right up! O.K. I'm done tooting my own horn now!
Old Sep 9, 2007 | 08:55 AM
53 willys's Avatar
I am a band adjustment believer....tons of people think it is not needed..
but then one day the trans quits working and the guy cant figure out why..low and behold the band adjustment bolt has become so loose it falls off into the pan..then your not going any where..
but if you don't follow the book you could really screw it up too
my.02
Old Sep 9, 2007 | 09:20 AM
chancey's Avatar
Can you give me some input on that band adjustment, i'm having some 1/2 studder on my truck 06 with 26K miles. Let me know the procedure on this, and also, i've read about increasing the line pressure, let me know as much info as you have. Also how much fluid does the tranny hold, i'm gonna up grade to bully dog fluid.
Thanks in advance
Old Sep 9, 2007 | 09:32 AM
ArXane's Avatar
Thanks in advance
Check out these two links for bad adjustment porecdures:
Band Adjustment:
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
https://www.dieseltruckresource.com/...ighlight=bands
Old Sep 9, 2007 | 09:35 AM
dbossdiesel's Avatar
I'm curious too! Mine has 81k on it and it has some hesitation from 1-2. Explain the prosess please! Thanks!
Old Sep 9, 2007 | 09:46 AM
Deesil's Avatar
Muted User
I adjusted mine @ 91K and they were right where they were supposed to be. Of course I loosened them up and adjusted them anyway, but absolutely no change in the tranny at all. My tranny shifts like a champ and always has, I was just checking them to be on the safe side.
Old Sep 9, 2007 | 10:46 AM
06megacabman's Avatar
Hey Chancey,
For the 06 (which is what I have in the megacab version) there is a TSB for 1-2 shift issues. They replace a silenoid valve and it fixed my issues right up. Just wanted to let you know so you don't go adjusting if not needed and may actually be a TSB instead.
Thanks in advance
Old Sep 9, 2007 | 12:04 PM
chancey's Avatar
So I should pull the bully dog out and bring it in for warrenty service right. and secondly, (TSB) that does stand for technical service bulletin, right. Thanks for all the help, that's the only Issue i've got, that **** bully dog and exhaust, works awesome.
thanks Megacabman
Old Sep 9, 2007 | 01:48 PM
efil4ynot's Avatar
At WOT, I get a very bad hesitation b/w 1 and 2. I have the 47RE and have checked the bands and they were right where they were supposed to be. If I tightened the adjustment bolt up more than stated, would that help to fix this?
Old Sep 9, 2007 | 03:21 PM
inarush76's Avatar
Don't suggest a tighter band adjustment. The proper clearance is needed for shift timing, servo travel, and enough clearance so that the band does not drag when it is released. The front band is only on in second.
James
Old Sep 9, 2007 | 06:49 PM
woodrep's Avatar
I did a post a week or so ago on the 1-2 shifting hesitation, cant make up it's mind which one to go into, issue. I changed the governor solenoid and adjusted the front band, and now my trans shifts good and firm where and when it needs to. Thank you to VZ and anybody else who posted to help keep me runnin!
Old Sep 9, 2007 | 07:13 PM
skynyrd's Avatar
when i was still running my stock tranny i adjusted my bands and it helped out alot with the shifting.
onehitwonder53
Apr 11, 2015 07:09 PM
FSR
Sep 9, 2009 07:22 PM
1985cucv
Apr 3, 2009 01:33 PM
hoghead
Nov 15, 2006 08:38 PM
broncobilly
Aug 24, 2006 11:52 PM
