7th gear added
Old Feb 5, 2007 | 08:10 PM
  #31
RAMRODD's Avatar
To bad you can't just replace 6th gear with a different size gear.
Old Feb 5, 2007 | 08:33 PM
  #32
belgianmagic's Avatar
THE ANSWER TO THIS PROBLEM IS A 'TWO SPEED REAR END FOR 2WH Highway operation... they make them for gravel trucks....you can not have it in high with the power divider ...So you make it lock in low for 4wd...! ta da
Old Feb 5, 2007 | 09:16 PM
  #33
hauliday's Avatar
Originally Posted by erics76
How about driving slower?
How about just being able to drive the speed limits most of what i do is J.I.T. deliveries { just in time ) so they dont want you driving below the speed limit just to save some fuel And driving a 100k plus a year if i loose 2 mpg you will notice it by the time your ready to trade trucks . So in other words just because it might work for you dont mean it will work for me
Old Feb 5, 2007 | 09:32 PM
  #34
scoggins's Avatar
Originally Posted by Longhorn06
I am not convinced that you would see better mileage if this was possible...at some point the engine will 'lug' and will become less efficient. Im not sure what the exact rpm would be, but im not sure you could maintain effeciency at 15-1600 rpm. Flat would likely be ok, but small hills and wind would affect this.
what is your rpm@ 80 mph?
mine is +- 2500 add 7th gear and drop the rpm to 2200
or make 65-70 mph around 1800-2000
I love the idea of having a broader range to go thru
Old Feb 5, 2007 | 10:09 PM
  #35
nitis's Avatar
I knew that we had beat the lack of gear ratio options to a slow death on this forum long ago and they almost got stirred up for no reason If it were so simple we would have never started this thread
Old Feb 6, 2007 | 03:09 PM
  #36
ridofpwrstroke's Avatar
Gear vendors. Great for towing and great empty. I wish I had 4.10's in my axles now. I dont know why you all hate the GV. I love mine and it works awesome. MPG and less engine wear. I have to change the fluid every 10,000 miles. Thats 48 oz. 17 bucks of fluid. It will save you on fuel. Plus it cruises real good at 75 at 1750. I am now getting 17.1 mpg at 75. 3600 miles on her now.
Old Feb 6, 2007 | 08:24 PM
  #37
D.Wiggs's Avatar
From everything I have heard, GV just can't handle the power we can throw at them. I will end up with over 1000HP and 2000 ft./lbs of torque and the GV just can't take that on a 10,000lb. truck!
Old Feb 7, 2007 | 08:26 AM
  #38
John DiMartino's Avatar
It isnt just the gear vendors that wont take that on a 10K truck!
Old Feb 7, 2007 | 11:38 AM
  #39
Last truck I had put out 508 hp at the wheels and 900 ft lbs. This new truck will never see that kind of cash flow dumped on it for engine mods. Most people wont. It was fun but reliability "I think" was less. Never let me down but only so many hp hours in a motor. Wiggs, in your case it prob wont work. For 99.6% of the others on here, it will be just fine. I plan on either putting a smarty or edge attitude on it and that is it. Want to keep the stock clutch as long as possible. My last truck was fast (never lost to anyone that I dragged against on the road, and I raced a bunch), but there will always be someone quicker.
Old Feb 7, 2007 | 01:25 PM
  #40
D.Wiggs's Avatar
I agree. The GV is great for ALMOST everyone; just not those looking to push the envelope!
Old Feb 12, 2007 | 06:37 PM
  #41
Dane Bramage's Avatar
I'm gonna get one (Gear Vendors OD/UD)... within next two weeks. I will have my PacBrake PRXB put in first (this week?). I've been on the fence a bit about the GV unit... unloaded highway RPMs though - bad for mileage and not optimal for engine longevity either I imagine. No desire to bomb my rig, so no worries on excessive torque @ the gears ~ these mods all about efficiency. Too bad that's so expensive up front! <tries to focus on ROI>
Old Feb 12, 2007 | 10:49 PM
  #42
coleo's Avatar
I phoned gear vendor directly a month or two ago and asked if they made their 2 speed for the g56 and was told no and that the line would be discontinued real soon
http://www.usgear.cc/dr_appprice.htm#dodge4
not even in their list of applications
as for the 7th gear in the transmission.... even though the g56 is bigger than the old nv5600 (i think thats what it was called) 6th gear is so small that it can barely handle the power out of the motor if you put another gear in there it would have to be so small to get the gear ratio that you wanted it would probably just wear out in a real hurry and we all know little chunks of metal going thru other spinning chunks of metal isnt good
Old Feb 13, 2007 | 02:09 PM
  #43
You phoned Gear Vendors? You have the US gear website posted. US gear is being discontinued and no applications for the dodge. The GV is the only unit available. I wish I had the US gear because you can use it in 4wd and you can engine brake with it.
06trx
Feb 26, 2007 06:09 AM
MMiller
Jan 8, 2006 08:14 AM
EMcBride
Aug 9, 2004 08:56 AM
DavidTD
Nov 26, 2002 05:09 PM
