gas mileage help
Old Feb 10, 2007 | 05:50 PM
usmarinetx's Avatar
Unhappy gas mileage help
im new to the diesel world if the following isnt obvious. my 06 gets 15.5mpg on a good day. is this normal? can i do anything to make it better? My old trans am put out 500hp to the rear wheel and still got 20-25mpg. i even drive like miss daisy to eek out a little more economy. im open to suggestions...please help!
Old Feb 10, 2007 | 06:03 PM
steelblitzkrieg's Avatar
DTR Detective
Fill out your sig, so we know exactly what you're running.
1. Patience if it's new, takes 20k unloaded to break-in and about 5-10k if you tow or load heavy.
2. I'm getting 15.9 city currently with 10k on it, no towing, 1/2 cord of wood is the heaviest I've loaded so far and that was only for 30 miles.
Old Feb 10, 2007 | 06:06 PM
1stdodge's Avatar
You didn't specify what truck you have and how many miles are on it.
15.5 in winter, in a cold climate, doesn't sound too bad.
I find that you loose 2mpg running winterized diesel. Plus the amount of time that it takes the engine to warm up in winter affects the mileage.
I get about 15 in winter and 17 in summer with my 06 MegaCab.
Old Feb 10, 2007 | 06:10 PM
DTR Detective
Also remember your Trans am probably didn't have 610lbs of torque and weigh over 7000lbs and chances are it was probably a bit more aerodynamic.
And if it's an auto use Tow/Haul when driving faster than 50mph.
And use hand calcs not the overhead, mine says 14.4mpg and hand calc is 15.9mpg.
Old Feb 10, 2007 | 07:28 PM
stickman73's Avatar
Holy Moly! I'm luck to get 12 in town with 23,000
Old Feb 10, 2007 | 09:59 PM
DTR Detective
Hotrod, much?
I'm in the SF bay area, I know my traffic must be worse.
45-60min for 23 miles.
Old Feb 10, 2007 | 10:20 PM
Almond Pale Ale's Avatar
why? doesn't this lock out the O/D?
Old Feb 10, 2007 | 10:28 PM
danc46's Avatar
I have an 06 with less than 2500 miles on it, purchased in early December of 2006. I was getting between 15.5 and 16.1 mpg hand figured with a mixture of Power Service diesel additive and Marvel Mystery Oil.
I recently tried a 50/50 mixture of Howe's Meaner Kleaner and MMO, 16 oz per tank. It jumped to 16.9 mpg, hand calculated on the first tank.
All driving was a mixture of city and highway.
I expect to get between 17 to 19 once the truck is fully broke in!
Old Feb 11, 2007 | 06:51 AM
SupaDupa's Avatar
JFYI here, and for future reference, diesels get "FUEL MILEAGE" not "gas mileage"!!!!!
Old Feb 11, 2007 | 10:30 AM
Tyler_02's Avatar
Whats the reasoning behind that?
I've been running winter fuel for the last 2 weeks (-30 degrees out) and the other day i drove from home to college and got 22.8 MPG doing 70 so i was pretty excited i have 15500 miles on it now.
Old Feb 11, 2007 | 10:48 AM
tacook's Avatar
15-16 city driving is just about right
Old Feb 11, 2007 | 11:09 AM
DTR Detective
Not on the 06's, it locks up the converter, no slippage loss of MPG.
2006 has O/D, T/H with O/D, and O/D off.
See above comment.
Old Feb 11, 2007 | 07:39 PM
using tow/haul on the 06 does that - what about 04s? All it does on mine is raise the rpms.
Old Feb 11, 2007 | 07:41 PM
DTR Detective
04 doesn't have that feature, sorry.
Old Feb 11, 2007 | 07:53 PM
thanks. I had read on here other posts about multiple push capability on the tow/haul button but every time I did that, all it did was climb rpms, thanks for confirming for me!
