6spd Manual tramission fluid change
ATF+4 is definety what Dodge calls for in the G56. There are fluids that claim to meet ATF+4 specs (like the amsoil) but are not actually labeled ATF+4 that are fine. Since your out of warranty on powertrain it doesn't really matter if you run an actual atf+4 like mopar or valvoline or one of the ATF+4 compatibles like the Redline C+ or Amsoil universal ATF.
And yes its 14mm allen to drain and when filling i pump it full until fliud comes out teh fill hole, then jack up the passengers side of the truck and add another 1/2 quart or so.
I did look it up and it is ATF-4 fluid that it uses. Same fluid is used in the powersteering resevoir. Intresting! Thanks to all for your input, I will be changing it this coming weekend
How long have they been running that fluid? The only thing that worries me is the detergents. Dont know if they will have a negative effect on the internal componets. I can see how it would shift easier. I think I will look deeper into this.
twhman
May 10, 2010 10:50 PM
PurNLoud
Jan 13, 2006 06:20 PM
westport
Nov 24, 2005 01:43 AM
