6 speed manual problems
Old Oct 31, 2009 | 07:47 AM
triton20x's Avatar
I have a 03 with 6 speed manual trans. It is getting hard to get into first and reverse, reverse more than first. When I first start it up not a problem but after I have driven it for while it gives me problems. Anyone had any problems like this?
Old Oct 31, 2009 | 08:11 AM
MikeyB's Avatar
Could be several things. First, when was the last time the fluid was changed? Sometimes new fluid will help with cranky shifting. Second is the hydraulics, maybe getting weak.
I found that shifting into 5th before going into reverse helps a bunch.
MikeyB
Old Oct 31, 2009 | 09:15 AM
rich's Avatar
Mikeyb is right, try a fluid change if it has been over 65k, if it still is hard to do then try pumping the clutch several times if that works then hydraulics are eak
Old Oct 31, 2009 | 09:24 AM
triton20x's Avatar
6 speed problems
I did change the fluid after it started acting up, did'nt help. I will try pumping the clutch to see if it is the hydrolics. Thanks for the info.
Old Oct 31, 2009 | 11:29 AM
rootercycles's Avatar
could be your clutch
Old Oct 31, 2009 | 01:01 PM
torquefan's Avatar
A big possibility is that the pilot bearing is starting to seize, and won't allow the input shaft to completely stop turning when the clutch is disengaged.
Old Oct 31, 2009 | 01:16 PM
Fisherguy's Avatar
That's what I'm thinking, how many miles on it?
Old Nov 2, 2009 | 05:30 PM
triton20x's Avatar
6 speed problem
218k, I hope it is just the pilot bearing.
Old Nov 2, 2009 | 06:10 PM
rich's Avatar
if you have 218 on the stock clutch then odds are its the clutch
Old Nov 2, 2009 | 06:13 PM
Fisherguy's Avatar
I think so too, if you're going to all the work to take it apart might as well change it while you're there.
Let us know how it goes.
DJ Turbo.
Oct 13, 2011 09:11 PM
fpr01
13
Sep 21, 2008 11:31 AM
Burkert
21
Nov 26, 2007 07:09 PM
MossyOakGlock
18
Sep 21, 2007 03:42 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
