6 Speed drain
6 Speed drain
I am about to pull out what little hair I have left!
How do you drain the '04 6 speed?? I know it has to be really simple, but for the life of me I cannot find a drain plug!
Any help will earn a cold beverage when passing thru Las Vegas!
Is that hole low enough to drain all the oil? It doesn't look like it...
When I drained mine I removed the LH PTO cover and wiped the transmission out with a clean rag and I found a magnet . I cleaned of the magnet with compressed air and put it back on the PTO cover.
Jim O
Jim O
Last night I drained the oil out of my 6 speed and refilled with Red Line MTL. Getting the oil back in is easier said the done.
The refill plug makes it a pain to get a funnel up high enough to pour the oil in. I went out today and bought a pump for quart bottles for next time.
Shifting is a little smoother...but I have only driven about 20 miles......we will see and I will keep everyone updated.
BTW....leaving on the 1st to go fishing and camping in Montana
I won't miss the 200 degree heat here in Vegas!
The refill plug makes it a pain to get a funnel up high enough to pour the oil in. I went out today and bought a pump for quart bottles for next time.Shifting is a little smoother...but I have only driven about 20 miles......we will see and I will keep everyone updated.
I went to home depot and bought some clear tubing. dont' remember the diameter, but it was small enough to fit in the fill home and was tight on a funnel. tan it up though the engine compartment and poured in the lube. works well .
HighTen
Dec 22, 2004 05:44 PM
