5.9 engine mounted air pump???
Old Dec 25, 2008 | 01:13 PM
turbosonoma's Avatar
anybody make one? i would like to rid my truck of the loud crappy elec pump that powers the air horns, so i would like to find a kit that mounts some sorta air pump to the engine that will fill up my tank when its running, the last time i looked was last year and nobody made one, but somebody must by now......
Old Dec 25, 2008 | 01:18 PM
norcaljr's Avatar
Check out this kit.
I have this setup for my Jeep and love it.
http://www.kilbyenterprises.com/KE-3100-K.htm
Old Dec 25, 2008 | 05:00 PM
thats EXACTLY what i was looking for, do you know if there is any other manufactures, or is this the best one to get?
Old Dec 25, 2008 | 09:11 PM
Checkmate's Avatar
You can convert an a/c pump into one easily, but I'm not sure how to keep it lubed. They will pump up to 120 quick.
Old Dec 25, 2008 | 09:31 PM
funcruise's Avatar
You can go to google and type in york compressor install and there is a good article on how to hook up an engine mounted air compressor there
Old Dec 26, 2008 | 02:37 AM
Moneywoes's Avatar
http://www.vmac.ca/index.php?underhood
Old Dec 26, 2008 | 09:38 AM
OOPS's Avatar
If you are using a rotary style pump, you have to put an oil drip on the intake side and on the output side; you put a COALESCING FILTER to take the oil out. If you use a York style pump they have oil in the crankcase so all you need is the COALESCING FILTER on the output. It is best to mount the COALESCING FILTER away from the pump. I had on mounted about a foot away from the pump and the air coming from the pump was hot enough to melt the inside of the COALESCING FILTER.
herb
Jul 18, 2008 08:25 AM
shotgunslg
Dec 19, 2007 12:00 AM
dover
23
Sep 23, 2005 11:07 PM
charger 69
Dec 12, 2004 01:54 PM
