4x4 problems
Old Dec 4, 2005 | 09:54 PM
CATSNOX900's Avatar
4x4 problems
when i put my truck in 4wd and turn the wheels (on snow) there is some chunking, clicking noise in the front end. kinda sound like gravel under the center caps almost. could this be bad u- joints or carrier bearings. i really havent had the time to tear the front end apart to see so i need a starting point. by the way there is no funny noises what so ever in 2wd. and it doesnt sound like it coming from the transfer case. the truck has aprox 85,000 mi.
Old Dec 5, 2005 | 12:57 AM
Its All Good's Avatar
gotta clarify something, when you mean turn the wheel, do you mean as the wheels start to roll or turn the steering wheel and the wheels turn right or left. Did you notice any leaks from the inside of the wheel area (alxe seal, bearing seal)? Do you have automatic or manual locking hubs? If the noise only happens when you are in 4wd, I would check out the hub area.
Old Dec 5, 2005 | 04:46 PM
CATSNOX900's Avatar
yeah sorry bout that i mean when i turn the steering wheel. also they are auto lock hubs, and no i have not seen any leaks. thanks any help is appreciated.
Old Dec 5, 2005 | 06:15 PM
kully560's Avatar
I had the same thing when in 2wd and in 4wd also was front axel ujoints, and also ujoint in front drive shaft and cv joint both at where drive shaft meets transfer case . dealer change all under warranty also hubs were hard to get off he ruined one and replaced it .I tried to have them put in the spicer joints but under warranty only mopar parts
Old Dec 5, 2005 | 06:40 PM
Mexstan's Avatar
Auto lock hubs????? Are you sure? Did you have them installed after you bought the truck? Please tell me more about them.
Old Dec 5, 2005 | 08:04 PM
phox_mulder's Avatar
Originally Posted by kully560
ujoint in front drive shaft and cv joint where drive shaft meets transfer case
I'll throw my vote in for the CV joint as well.
Gravel in a hubcap is exactly what mine sounded like when it went.
phox
Old Dec 5, 2005 | 10:49 PM
CATSNOX900's Avatar
thanks guys that what i was thinkin it was too stinks cuz my warrantee is up so looks like ill at least be able to be in some nice greaseable ones
DJ Turbo.
Oct 13, 2011 09:11 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
2500
19
Sep 27, 2006 11:50 AM
1320
Jul 25, 2006 10:57 PM
Ridgetop
Jan 26, 2006 02:18 PM
